• Locomotion...
    Luke J. Barker • 10/11/2018 at 15:01 • 1 comment
    Last night I worked on how to steer the wheel assembly.  I always liked how old toys incorporated this type of motion, once it bumps into something, it just changes direction.  I attached a servo arm to mine so I can steer the direction I want to go.  The motor ran nicely using 5v and the roboShield motor output control.
  • He talks...
    Luke J. Barker • 10/10/2018 at 13:53 • 0 comments
    I trigger the message using his Ultrasonic vision
  • Magic Mike's Latest Moves...
    Luke J. Barker • 10/09/2018 at 15:34 • 0 comments
  • Eyes and arms and head...
    Luke J. Barker • 10/09/2018 at 02:30 • 0 comments
    The Ultra sonic sensor mounting went well inside Magic Mike’s head.   I have his head put back together and all the servers mounted back into his body. I’ve programmed roboShield to move the arms and head through a test sequence.
  • Some Eyes for Mike
    Luke J. Barker • 10/08/2018 at 19:58 • 0 comments
    Here I am preparing to add an ultrasonic sensor to the factory eye plate.  I won't be able to use the red eye cover to make it work properly.
