Locomotion...
10/11/2018 at 15:01 • 1 commentLast night I worked on how to steer the wheel assembly. I always liked how old toys incorporated this type of motion, once it bumps into something, it just changes direction. I attached a servo arm to mine so I can steer the direction I want to go. The motor ran nicely using 5v and the roboShield motor output control.
He talks...
10/10/2018 at 13:53 • 0 commentsI trigger the message using his Ultrasonic vision
Magic Mike's Latest Moves...
10/09/2018 at 15:34 • 0 comments -
Eyes and arms and head...
10/09/2018 at 02:30 • 0 commentsThe Ultra sonic sensor mounting went well inside Magic Mike’s head. I have his head put back together and all the servers mounted back into his body. I’ve programmed roboShield to move the arms and head through a test sequence.
Some Eyes for Mike
10/08/2018 at 19:58 • 0 commentsHere I am preparing to add an ultrasonic sensor to the factory eye plate. I won't be able to use the red eye cover to make it work properly.
Luke J. Barker
