Hi friends. Today i will show you Home Make a Cheap Hot Air Soldering Station
Watch video below
Make PCB
I use Eagle software for make layout. You can download all of thing need to make PCB here. You can make at home by yourself but you can use my gerber file and upload to https://jlcpcb.com/m for make PCB online. I order PCB from https://jlcpcb.com/m alot of time and i alway get PCB with high quality only 2$ for 10PCB and Big Discount on First order Shipping.
![](https://cdn.instructables.com/F6P/S08G/JN4VGVDO/F6PS08GJN4VGVDO.LARGE.jpg)
![](https://cdn.instructables.com/FC1/EZ85/JN4VGVF1/FC1EZ85JN4VGVF1.LARGE.jpg)
![](https://cdn.instructables.com/FLB/Y6C6/JN4VGWZD/FLBY6C6JN4VGWZD.LARGE.jpg)
![](https://www.instructables.com/files/deriv/FGA/4X6P/JN4VGWZH/FGA4X6PJN4VGWZH.LARGE.jpg)
LIST PART:
CAPACITOR: 14UF/16V X2
100UF/16V 100n X2
DIODE 1N4004 X2
DIODE ZENER 9V1/1W
FUSE 2A 250V
PORTENTIOMETTER 10 KILO OHM
PORTENTIOMETTER 100 KILO OHM
IC TL431
IC LM358
RESISTOR 4K7 X3
RESISTOR 4M7
RESISTOR 1K X2
RESISTOR 100K
RESISTOR 1K5 X2
PORTENTIOMETTER 3362P 5K
RESISTOR 51K
RESISTOR 5K6
RESISTOR 33K
RESISTOR 390 X2
RESISTOR 1K2/2W
LED 5MM
Triac BTA12
MOC3020
LM317
IRFZ44
Screw Terminal Block Connector KF128 pitch:5.08MM/0.2inch Green 5.08mm KF128 X2 Plug 8 pin AC 220V
Hot Air Gun Handle With Blower fan for Soldering station
![](https://www.instructables.com/files/deriv/FMI/ABUR/JN4VGX5J/FMIABURJN4VGX5J.LARGE.jpg)
![](https://cdn.instructables.com/FO1/AMYY/JN4VGUOT/FO1AMYYJN4VGUOT.LARGE.jpg)
![](https://cdn.instructables.com/FME/K4UO/JN4VGUNG/FMEK4UOJN4VGUNG.LARGE.jpg)
![](https://cdn.instructables.com/FWF/G1N9/JN4VGUQ7/FWFG1N9JN4VGUQ7.LARGE.jpg)
![](https://cdn.instructables.com/FT6/KWCX/JN4VGURK/FT6KWCXJN4VGURK.LARGE.jpg)
![](https://cdn.instructables.com/FYW/I84B/JN4VGURM/FYWI84BJN4VGURM.LARGE.jpg)
Finish and Test Circuit
![](https://www.instructables.com/files/deriv/F2O/QEAC/JN4VGY0B/F2OQEACJN4VGY0B.LARGE.jpg)
![](https://www.instructables.com/files/deriv/FHA/PCY8/JN4VGY0C/FHAPCY8JN4VGY0C.LARGE.jpg)
![](https://www.instructables.com/files/deriv/F8Z/5BHG/JN4VGY1Q/F8Z5BHGJN4VGY1Q.LARGE.jpg)
hello very good project would need a screen to know the temperature
