THEORY
The main objective of this practice is that we start as a sudden, is that we are able to work with an 8952 microcontroller, that we are able to work with the assembly language and that we are able to combine everything we know about timers and interruptions.
The original idea of the practice was to finish in the first 12 hours of work, however, for reasons of understanding and hard work, as well as stress and lack of sleep was assigned another delivery date of this.
Among the fundamental parts of this practice was to make us work as a team, as well as to make us work under pressure, something that has not stopped doing for many errors that arise and problems that have to be solved.
DESIGN
The main objective of the practice is to make a digital clock where we can assign an alarm at the time we want and also buzzer so that this is the closest thing to an alarm clock.
To be as similar as possible to an alarm clock, we must use 7 segment displays, the numbers must be distributed in a way HH, MM, SS.
The circuit must have external interruptions, to change in the displays between the clock and the alarm, as well as to adjust alarm or time.
SCHEMATIC
Lilia Lobato
project.director
HIGEDARUMA
