Tailpiece-4String-R3.stl
A 4-string tailpiece! Print this with lots of plastic, it needs to be strong.
Standard Tesselated Geometry - 483.29 kB - 07/15/2019 at 23:13
Download
PegShort-R1.stl
This may work with the Pegbox-pegs, but may also need a lot of sanding/filing. I still recommend the Grover tuners, but if you want to try pegs, give it a go.
Standard Tesselated Geometry - 379.96 kB - 07/15/2019 at 23:13
Download
Pegbox-4String-Grover6-R3.stl
This updated Pegbox has some minor changes.
Standard Tesselated Geometry - 655.16 kB - 07/15/2019 at 23:13
Download
Pegbox-4String-Pegs-R4.stl
This updated Pegbox has smaller holes for smaller pegs.
Standard Tesselated Geometry - 665.80 kB - 07/15/2019 at 23:12
Download
Bridge-R10.stl
The bridge is updated for the new body. Any bridge R8-R10 should work OK.
Standard Tesselated Geometry - 236.31 kB - 07/15/2019 at 23:12
Download
Bridge-Generative-R4.stl
Reduced the height of the generative bridge for better string heights.
Standard Tesselated Geometry - 3.54 MB - 07/15/2019 at 23:12
Download
Bout-R7.stl
A new body! This body has many improvements. I have a blog post about it coming soon.
Standard Tesselated Geometry - 1.26 MB - 07/15/2019 at 23:11
Download
Complete Modular Fiddle Acoustic V1-R6.stl
This is a STL of the entire assembly. Use this to edit the design with mesh modeling software. Some parts are outdated!
Standard Tesselated Geometry - 5.15 MB - 12/10/2018 at 23:32
Download
Pegbox-4String-Pegs-R3-Oriented.stl
This is a ground up redesign of the Pegbox. This new design offers better mechanical support, easier tuning, different aesthetics, and a fun way to hang your fiddle. This Pegbox is designed to be reamed and set up with traditional violin pegs.
Standard Tesselated Geometry - 646.76 kB - 12/10/2018 at 23:32
Download
Neck-4String-R6-withSupport-Oriented.stl
This Neck is a ground-up redesign. I've improved Neck profile for printing, improved nut shape, and improved aesthetics. This STL includes the needed support material.
Standard Tesselated Geometry - 550.47 kB - 12/10/2018 at 23:32
Download
Neck-4String-R6-noSupports-Oriented.stl
This Neck is a ground-up redesign. I've improved Neck profile for printing, improved nut shape, and improved aesthetics. This STL does not include the needed support material.
Standard Tesselated Geometry - 407.50 kB - 12/10/2018 at 23:32
Download
Bridge-4String-R9-Oriented.stl
Bridge height is updated for better string heights.
Standard Tesselated Geometry - 206.82 kB - 12/10/2018 at 23:31
Download
Pegbox-Grover-R6-oriented.stl
This Pegbox fits Grover 88B, 6-series, or 3055 tuners. R6 is angled for better string path to nut and improved mechanical load on Pegbox. Oriented for printing.
Standard Tesselated Geometry - 382.60 kB - 10/23/2018 at 21:56
Download
Bridge-Generative-R3-oriented.stl
This bridge is designed using Autodesk Generative Design. It sounds very different! Try it as your first experiment. Also check the youTube videos for demonstration.
Standard Tesselated Geometry - 4.27 MB - 10/15/2018 at 22:54
Download
Body-R5-withSupports-oriented.stl
This is the Body with modeled supports. Oriented for printing. There is an updated Body file! See R7.
Standard Tesselated Geometry - 1.41 MB - 10/15/2018 at 21:14
Download
Body-R5-oriented.stl
The Body without modeled supports. Oriented for printing. There is an updated Body file! See R7.
Standard Tesselated Geometry - 1.04 MB - 10/15/2018 at 21:14
Download
