Almost every pin is in use or broken out! I've ran all checks that eagle offers me, but I refuse to order because of the time!
There'a a via on the power line on the right o.O - fixed
So beautiful! - Sometimes I only upload them to see what they would look like :3
This is the LCD board that I also have to check again and order soon, not just this evening. It makes sense to have this separate, since the game boy classic also had a separate lcd board - so that's what I do, staying original :D I should make one pin header side 5V and one 3.3V and add some level converting stuff, before I order.
It sounds like a wise rule! I had a board ready to go this weekend, but got distracted and forgot to send it. I looked at it again this morning, and ripped up all the traces and re-routed it. It's funny how different things can look after a day or two.
Your "because of the time" sentiment regarding ordering PCBs keeps coming up... I was trying to chug one through last night, now it's midday... probably best to wait a day or two.
well the rule could be adjusted to "sleep over it", not actually implying when to be asleep ;)
For PCBs roughly the same rules apply as for Gremmlins.
Don't order after midnight ;-)
BTW: Why does it appear as C1..C4 are only connected on one side? Ahh... Well because they are connected to Ground and the Polygon is not active ;-)
BTW: What are those holes for? If you want to use screws, then the ISP Header is maybe a bit near? For M3 Screws i also like to use vias with 3.2mm drill and 5.0mm Diameter, so the Screwingplace is almost safe :)
BTW: What are thos circles beside the drills?
Best regards and don't make the gremmlins angry ;)
@Stefan-Xp
The Ground polygon gets me too sometimes, but they're so handy.
The circles and drillholes are for the socket, it has a big and a smaller hole next to each other. The circle is drawn on the dimension layer since there is no drill big enough for it.
Thank you. Some Board Houses are offering milling for free, maybe you could also put it on the milling layer...
The milling layer hmm. I have another board (the LCD one) at order that will use this layer. Seems like I just have to wait on all the things ordered and see what works and what not :)
