Hackaday.io Hackaday.io
Sign up Log in
Data Display Glasses
Using an Arduino, we hope to create a projection device that attaches to glasses and can display data from an external device thru bluetooth
yash-shekarYash Shekar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.1k views
0 comments
6 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 7
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.1k
0
6
4
Team (2)
  • yash-shekarYash Shekar
  • atharv-guptaAtharv Gupta
Join this project's team
ongoing project
This project was created on 10/19/2018 and last updated 7 years ago.
Description
Our goal is to create an optical head-mounted display (OHMD) that can be attached to any pair of glasses. These glasses can be worn with a helmet and deliver information to the driver without forcing them to look away. Information such as speed, GPS directions, and time could all be displayed within the driver’s field of view with absolute ease for a motorcyclist to access.
Files
Prototype 3.stl
Standard Tesselated Geometry - 10.53 kB - 05/01/2019 at 12:58
Download
Components
  • 1 × 12" x 12" Acrylic See-Through Mirror
  • 1 × 30mm Dia. x 100mm FL, Commercial Grade, Plano-Convex Lens
  • 1 × Arduino Pro Mini 328 - 5V/16MHz
  • 1 × USB Micro-B Breakout Board
  • 1 × SparkFun Micro OLED Breakout
View all 7 components
Project Logs
Collapse
  • Published Materials
    Yash Shekar • 06/03/2019 at 12:54 • 0 comments
    Presentation: https://docs.google.com/presentation/d/1R8bivnln9xGkLMyh3t5CRUr5okgo9ADQIWXl2KOLLrk/edit#slide=id.g5a408aea72_1_0
    Paper: https://docs.google.com/document/d/1pNHF6GL1mFo28sQaE4hFqXHgtCqMwo0WGynOhFob5kw/edit
  • Final Progress Update
    Yash Shekar • 06/03/2019 at 12:51 • 0 comments
    Hardware:
    The hardware for this project was, for the most part, successful. We were able to achieve our major goals of creating a lightweight and durable case that houses a compartmentalized electronics system, along with a system of mirrors and a lens to display an OLED image onto the retina. The whole case is also easily portable, lightweight, and wearable, as we were able to attach it to a pair of large safety goggles. Below are several pictures of the goggles on a person.
    Side view of the Data Glasses, with a fully parallel and appropriately angled Data Glasses case attached to the side of the goggles
    Top View of the Data Glasses, showing the angle of the reflector towards the eye.
    A side-by-side comparison of our Data Glasses with the Google Glass, a similar wearable HUD created by Google
    Software:
    The software aspect of our project was far less successful. We had serious difficulties in connecting the Bluetooth module to the computer and running a connection between the Data Glasses and the SoftwareSerial on the computer. There was some unidentified issue in the connection and pairing process, as the computer was unable to connect to the HMSoft Bluetooth output of the module. Thus, the Bluetooth aspect of the Data Glasses was a failure. However, the OLED worked perfectly and we were easily able to code it to display text and images. The final product incorporates a stopwatch timer displayed on the OLED screen that can be started and stopped through the press of a pushbutton on the exterior of the glasses.
  • Progress Update (5/1/19)
    Yash Shekar • 05/01/2019 at 12:54 • 0 comments
    For the past few months, we've been prototyping. We spent a lot of time tinkering with the distances between the optical elements of the HUD and reprinting the case for the device based on our changes. Additionally, we've begun soldering together the final electronic components for the device and will shortly have a finished product.
    Here are some pictures of our progress:
  • Proposal & Presentation
    Atharv Gupta • 11/02/2018 at 13:06 • 0 comments
    11/2/2018
    Attached below are our project proposal and the coinciding Google Slides presentation!
    Presentation: https://docs.google.com/presentation/d/1CHY9iyeaUaSKvYnJnemr1zTlYbIr6vZvyqGy7P4uZ_Y/edit?usp=sharing
    Proposal: https://docs.google.com/document/d/1LqVZMNPXAbv1dEO7LenlhzlkGjnuWhN2tCKBMEgIDkE/edit?usp=sharing
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
Official Hackaday Prize Entry
General data acquisition and local data display using a Raspberry Pi.
Project Owner Contributor
RasPi Modular Acquisition Setup
nocternalNocternal
The project was initially designed to acquire real-time race car data for BAJA-SAE competitions
Baja Race Car Dashboard
harshsrighharshsrigh
The 2018 Hackaday Prize
Track the prices of your favorite coins–Ethereum, Litecoin, Bitcoin, Dogecoin, and others–and display'em on your desk using the ESP8266.
ESPicker | Cryptocurrency Ticker
acrobotic-industriesACROBOTIC Industries
Data logger for karts.
TVG KDL v4.0 - Kart data logger
pinteamihaitapintea.mihaita
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Data Display Glasses ", please tell us the reason.
Send message
Remove Member
