The goal of this project is to verify usefulness of a Raspberry Pi acquisition system using a small touchscreen display. During the planning stage of a more specific acquisition system, it became clear that a general acquisition setup would be useful for future projects.
The components are off the shelf hardware, except for perhaps the sensors. The software for querying the sensor and writing data to files will be coded in python for this system. The expectation is that standard linux functions will be utilized for the wifi connection and file sync operations. As stated, one of the project goals is to replace the LCD monitor with a small TFT display to minimize the power and space required for the hardware, though a standard display may function just as well if power/space limitations are not an issue.
An MSP430 launchpad board will be used to create the temperature sensor for this build, though the sensor itself is less important at this point in the project than the data flow from the sensor.
The project is currently in the early development stages. The RasPi hardware has been successfully powered. Display and input functions have been verified. Operating system is functional. Next up for integration is the WiFi module.
Nocternal
Clovis Fritzen
Initial State
Jeff Thomas
Michil783
