This file contains the dimensions for drilling the holes into the boards of the mold. I printed them and placed them onto the boards and carefully centrepunched each hole through the paper into the wood before drilling, this way i got pretty precise results. Also note that due to the fact i could only print A4 format the "mid-upper linear-rail board" stencil has to be turned around to centre punch the other side of the board. You should also make sure you drill all the holes for screwing together the mold. it helps to put together everything loosely to make sure you didn't forget anything before start assembeling. Also you have to drill the holes into the Base-plate, i did that free hand by drawing the contours around the mold onto it and then placed some holes where i thought they would be needed.
Adobe Portable Document Format -
20.52 kB -
10/23/2018 at 09:38
