Code updates
11/19/2018 at 07:25 • 0 commentsSmartphone application: allow sweep mode configuration of frequency step in KHz an step duration in ms (does not work if > 10ms)
programming of ADF4351 (on ESP32): fast lock mode now works, muxout pin outputs the digital lock signal
Jose Luu
