Hackaday Belgrade.step
STEP file 3d model of a populated badge board for modelling your own enclosure around.
step -
16.91 MB -
11/12/2023 at 23:31
Download
Supercon Badge Enclosure All Keys Recessed Letters.zip
Keys with the letters recessed on them. Should be easier on the fingers than the ones with raised letters. Doesn't include the D-Pad or Space Bar models.
application/x-zip-compressed -
23.13 MB -
10/30/2018 at 16:30
Download
Supercon Badge Enclosure All Keys.zip
All of the keys with raised letters. This might not be so comfortable to type with. I had to compress it because it is a large file. This one also includes the Space Bar and the D-Pad. The "recessed letters" version in the other file is probably better.
x-zip-compressed -
26.55 MB -
10/30/2018 at 14:56
Download
Supercon Badge Enclosure Front.stl
Front of the enclosure. A little tall, leaves plenty of room inside the enclosure. Print Inside down. Probably should put some felt around the bottom of the key holes so that it doesn't rattle. Might need a little extra plastic at the bottom of the key holes if it rattles too much.
4.27 MB -
10/30/2018 at 14:24
Download
Supercon Badge Enclosure Back.stl
Back of the enclosure. Probably want to print it with the inside down for best results. Gonna need lots of support material... Needs 1/2" #4 screws to hold it together. A little worried about the acrylic backing I've heard that badges have. Can it be removed? Should I accommodate for it? This version doesn't.
2.06 MB -
10/30/2018 at 14:23
Download
Supercon Badge Enclosure Dpad.stl
D-Pad for arrow keys. Hopefully it rocks nicely and doesn't jam...
2.36 MB -
10/30/2018 at 14:22
Download
Supercon Badge Enclosure Key (print 50).stl
Key with no letter on it, if you like smooth keys and don't mind drawing your own letters on. Need 50.
Standard Tesselated Geometry -
1.24 MB -
10/30/2018 at 14:22
Download
Supercon Badge Enclosure LED Lightpipe.stl
Lightpipe to bring RGB LED light to the surface. Print in transparent or translucent untinted plastic.
357.89 kB -
10/30/2018 at 14:21
Download
Supercon Badge Enclosure Expansion cover.stl
Cover for the expansion board connection. TODO: Make some sort of locking mechanism to hold it in.
78.30 kB -
10/30/2018 at 14:21
Download
Supercon Badge Enclosure Spacebar.stl
Large spacebar. Hope it works with the single switch...
106.63 kB -
10/30/2018 at 14:21
Download
