We offer a bundle including all necessary components for this project in our shop.
Control your audio system with a touchscreen! We show you how you can build a budget setup with a Raspberry Pi and Max2Play.
Just follow the instructions from your touchscreen and make sure everything is well adjusted using spacers and screws. Then put the sound card on top of the Raspberry using the GPIO connector bar. We are using a HiFiBerry DAC+ light for our system. Its affordable yet powerful nature combined with its small size makes it perfect for this project.
Check the dimensions of your sound card's output and its distance from bottom of the touchscreen. With these specifications you can mark the area on the case that has to be removed in order to be able to connect your sound card
Use a drill to bore a hole where you have marked the exits for the sound card. Then check if the case fits comfortably onto the system. If not, just extend the holes until there is no pressure on the case anymore.
You can find the case for this whole system in our shop.
We also offer a free template for the right drill locations for HiFiBerry's DAC's on our website.
Since the two peripheries, screen and sound card, both need a lot of juice to run properly, we need to give the sound card an additional power source in the form of the 5 volt connector on the touchscreen. However we cannot connect the two yet since the connectors on the sound card are only for the Raspberry Pi. That is why we need to solder a little line of five connectors onto the top of our sound card. We just need two connections for the power supply, the first and third hole, so we only need to solder in two places. Once those two are rightly connected and sit strong on the sound card, we need to bend the connectors a little in order to not have them stick out in our case. Now that this new ridge is added and conformed to the rest of the system, we just need to connect the two cables and all the hardware is in place.
