Plastic gearbox with 4 times the number of teeth engaged with a central output.
You must be aware of Gabrael Levine's open torque actuator https://hackaday.io/project/159404-opentorque-actuator
This looks very interesting! I don't know what you're trying to build, would you explain it a bit more?
its a gearbox 🙄
Yes, delete it Cancel
You are about to report the project "RFX gearbox", please tell us the reason.
