Not only less wires, but print faster and more stable
auto level print
here is a video that show the auto home trigger position precision every time.
use optical tracking tangled filament or run out
optical tracking chip PAT9125
there are one heater,temperature sensor,2 fans.
Yes. So one could think about a separate microcontroller on the head with some kind of (wired) data bus, but I would not trust on a bluetooth link in this case.
This seems interesting, but I can see a potential to create a whole lot of new problems in an attempt to solve the problem of too many wires running to the extruder. Most of the issues I foresee have to do with latency and clock synchronization, but connection reliability is sure to be another one. I'll be interested to see how you overcome these problems.
