Any other uses?
11/01/2016 at 15:38 • 0 commentsOkay, so some of you may ask "what other things is this good for"? At the heart of this project is a 2.4GHz amplifier that increases the output power, and is also spec'd to increase gain by a few dB. This is not exclusive for use with WiFi, we can use any 2.4GHz source and it will still amplify the transmit power. This is not very useful for Bluetooth and WiFi, since these radio protocols require both ends to have good signal both ways. One use case is to have a radio that can still function one-way. NRF20L01 is a 2.4GHz transceiver, which is very cheap BTW, and does not have a radio protocol similar to BT or WiFi. It is able to send raw data from a micro-controller or computer. Similar to shooting at someone with a gun, you don't necessarily need a confirmation from that person by asking if he's shot. If you can see them go down, or get hit you have visual/audible confirmation that contact has been made. Similar to this is radio control; if the receiver can receive your commands, it does not necessarily need to send back telemetry data to be able to do process the command you sent. It only needs to do a checksum on the receiving side to confirm on itself that it has received the correct and complete command.
Sadly, shipping from China is very slow, and I'm currently stuck until parts have arrived, but we can see where this project is going.
Power Supply
10/18/2016 at 00:26 • 0 commentsSo I decided to make the battery pack a bit more permanent for now by mounting it on a perf board. I'm still waiting for the other charging circuit, and DC converter which is more compact and better than the one I'm using now.
Wood Stock
10/14/2016 at 11:11 • 0 commentsI was finally able to actually attach the thing to a proper stock. It took me quite a while since I don't have the right tools.
TacticalNinja
