Project Status
11/26/2018 at 06:27 • 0 commentsThe transmitter side has been successfully implemented. We are able to modulate the IR led at 38Khz and are able to encode a particular bit pattern which is also received by the receiver TSOP1838. The images taken on the DSO for different bit patterns have been attached. We are able to perform required functionality for one pattern however we are still working on how to distinguish the different patterns of decoded output of the receiver.
