I noted in the previous log that the failure to run at faster baud was probably clock related. Today I built a binary that dumps the oscillator and clock configs to see how the bootloader and reboot works, and here's what I found - "Letting the bootloader configure the clock" is bad.
Here's the clock config from both:
OscillatorConfig:
OscillatorType:15 (all of them)
HSEState:0
LSEState:0
HSIState:1
HSICalibrationValue:16
LSIState:0
PLLConfig:
PLL.PLLState:1
PLL.PLLSource:0
PLL.PLLM:16
PLL.PLLN:192
PLL.PLLP:2
PLL.PLLQ:4
Obtaining Clock Config:
Obtained Clock Config
ClockType:15
SYSCLKSource:0
AHBCLKDivider:0
APB1CLKDivider:0
APB2CLKDivider:0
Flash Latency:5
So, that's what is wrong. If I attempt to initialize the oscillators, the board hangs, so I need to debug to this and figure it out.
lol at this rate you might figure it out by the end of the year
Unlikely I'll have everything running. I'd be happy if I could just run a stripped down Marlin build as a starting point.
