sbaseloader.bin
The Lerdge-S base loader (if you brick your board and are comfy finding SWD, this would let you reset it).
macbinary -
58.79 kB -
06/17/2020 at 16:08
Download
lerdgexboot1.0.2.patched.bin
Patched bootloader that does not reset security bits on startup. Must be loaded directly with an ST-link, will not load correctly through the lerdge X boot updater
octet-stream -
64.00 kB -
01/10/2019 at 18:33
Download
ST7796S.pdf
This appears to be the LCD controller - most of the commands match up to what we see in the code.
Adobe Portable Document Format -
3.40 MB -
01/09/2019 at 18:28
Preview
resetlerdge.sh
script to call and then flash. Be sure to adjust paths as appropriate.
x-sh -
288.00 bytes -
01/03/2019 at 16:16
Download
lerdge_program.cfg
openocd script for resetting.
cfg -
312.00 bytes -
01/03/2019 at 16:15
Download
lergdekloader.bin
This is the base bootloader from a lerdge-K system.
macbinary -
64.00 kB -
12/19/2018 at 19:41
Download
lerdgebaseLoader.bin
This appears to be what exists at 0x8000000 on lerdge X boards.
macbinary -
128.00 kB -
12/09/2018 at 21:05
Download
lerdgedecrypt2.py
Now supports encryption and decryption of lerdge firmware.
x-python-script -
4.44 kB -
12/06/2018 at 15:37
Download
