My code wasn't taking control of the lerdge, as I might have mentioned, and with a little bit of in-memory debugging, I determined that we never exit the clock setup. I cloned the arduino variant from the discovery 407, which means I basically ignored all the normal guidance - you're supposed to run the cube, generate a definition for the board,a nd copy the clock init out of that with all the appropriate peripherals set up.
I'm on a mac and having trouble getting it to run, so I'm looking closer at the hardware and not seeing the obvious style of crystal I"m used to on the lerdge-X. So tomorrow I'll probably go part by part until I figure out what it is. Then I can generate a proper definition and try again to get proper Arduino code running.
The crystal on on the board is 25MHz and is located in the middle of the board close to the MCU. See here :
https://i.imgur.com/QOOKtRi.png
