Hackaday.io Hackaday.io
Sign up Log in
Pneumatic ControlRouter System
This is basically a CNC made from e-waste materials,that works effectively in 2.5D mode
g4ce60g4ce60
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
3 followers
  • Description
  • Details
  • Files 5
    • View all
  • Components 13
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
221
0
3
2
Team (1)
  • g4ce60g4ce60
Join this project's team
  • YOUTUBE
MISC
ongoing project
This project was created on 12/05/2018 and last updated 7 years ago.
Description
Pneumatic Control Router System Using E-waste material.
Details
Files
Final Report.pdf
Adobe Portable Document Format - 1.37 MB - 12/06/2018 at 17:56
Preview
my cnc v1.2.pdsprj.pdf
Stepper Motor Driver Circuit Board Layout (top and Bottom)
Adobe Portable Document Format - 70.05 kB - 12/06/2018 at 17:57
Preview
my cnc v1.2Bottom.pdsprj.pdf
Stepper Motor Driver Circuit Board Layout (Bottom)
Adobe Portable Document Format - 43.76 kB - 12/06/2018 at 17:57
Preview
relay spindleMaster.pdsprj.pdf
Circuit for the relay that controls the spindle, on/off
Adobe Portable Document Format - 17.75 kB - 12/06/2018 at 17:57
Preview
PCB LayoutCircuit.pdf
Adobe Portable Document Format - 19.92 kB - 12/06/2018 at 17:57
Preview
Components
  • 3 × Stepper Motor Used stepper Motor that are in good condition
  • 3 × Stepper Drivers Used to control Motors, as stepper motors tend to sometimes skip steps,these will contol the speed, and provide accuracy of rotation and position. (they are for Z,X and Y Axis)
  • 6 × Resistors 1Kohm
  • 1 × Switch SPST, Turn ON/OFF the system
  • 1 × Relay +5v
View all 13 components
Log In/Sign up to comment
Sign up with Github
OR
This a Google Assistant Control Car that works on your voice Commands that are given by you to Google Assistant.
Project Owner Contributor
Let's Create a Google Assistant Control Car Using
shahbaz-hashmi-ansariShahbaz Hashmi Ansari
In this guide, we’ll walk through a creative example where you can control the brightness of your Windows PC using BLE
Control Windows Computer Over BLE Using BleuIO
sheikhsheikh
A simple triangular pattern formation using three robots, by autonomous optimal position allocation in the pattern
Optimal Allocation in Pattern Formation
dharshan-bashkaran-lathaDharshan Bashkaran Latha
A box of relays, outlets, and wires.
Home Automation
bobby-christopherBobby Christopher
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Pneumatic ControlRouter System", please tell us the reason.
Send message
Remove Member
