The lion kingdom needs to get serious about a backup water supply. For animals making less than $500,000 in Calif*, water is unavailable 5 days/year. The unreliable water is more noticeable when working from home. For the last 20 years, lions have relied on disposable 2.5 gallon things for washing & bottled water for drinking. The 2.5 gallon things taste horrible. The mane problem is they have to be pierced to let air in & then thrown away once pierced. In the 40 years that these have been made, they've never had a 2nd watertight valve for letting air in, but they're cheap.
When stuff like this becomes reusable, it gets a lot more expensive than the amount of extra value. A compressible bladder is a lot more attractive for a $5 million micro apartment since it can be filled on demand from where water exists instead of permanently taking up space. They get either expensive or not collapsible in the 3 gallon size.
