So after burning $15 on a watt meter, the 22 year old 2.5hp Craftsman came in at >1150W starting & 900W constant power. The internet may differ in opinion, but $100 inverters these days are rated for 2KW peak & 1KW constant power.
There's also a 1.5KW/ 3KW peak one.
The mane problem is $100 of LIPO would provide 1kW for 14 minutes of vacuuming before the batteries were destroyed.
https://hobbyking.com/en_us/turnigy-5000mah-3s-20c-lipo-pack-w-xt-90.html
$100 of deep cycle lead acid would last 1.4 hours, but this would take up the entire apartment just to do 1 thing.
This is still cheaper than what a gasoline generator would cost. Gasoline generators don't have a peak & constant power. 2KW from gasoline is $600.
It seems the biggest inverters are intended to be powered directly from car battery terminals while running the car. There isn't a cost effective way to power them from standalone batteries. The vacuum would only be used for cleaning the car & the carbon monoxide fumes would help to loosen dirt.
