1Solder on all 19 LEDS paying attention to the LED orientation on the silkscreen.
- The center LED is the only one that is not paired so it is very important that it is in the correct orientation. For the rest it is ok to have them all inverse (or just the spokes or just the ring) because this is charlieplexed so these 18 LEDs are in groups of 9 opposing pairs.
2Solder the capacitor onto the PCB.
3Solder the ATtiny13A onto the PCB.
4Solder the Resistors onto the PCB.
5Solder the power cable onto the PCB.
6(Optional) Chain them together by soldering cables onto eachother.
