Hackaday.io Hackaday.io
Sign up Log in
Raspberry Pi IOT module
The module is supposed to handle power management, control peripheral devices and in addition add GSM and GPS functionalities
madivakmadivak
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
414 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
484
0
414
1
Team (1)
  • madivakmadivak
Join this project's team
hardware
ongoing project
iot raspberrypi embedded systems engineering wireless systems gps power systems Altium pcb manufacturing prototype Robust Systems
This project was created on 12/09/2018 and last updated 7 years ago.
Description
To enable The raspberry Pi function as an IOT device a couple of things needed to be added which include: GSM chip, GPS and on top of that added some few functionalities among them supplying power to various components while monitoring consumption and remote control of peripheral devices.
Project Logs
Collapse
  • Raspberry PI IOT Module Testing (Mounted)
    madivak • 12/09/2018 at 19:28 • 0 comments
  • Raspberry Pi IOT module Manufactured PCB
    madivak • 12/09/2018 at 19:27 • 0 comments
  • Raspberry Pi IOT MODULE PCB DESIGN
    madivak • 12/09/2018 at 19:26 • 0 comments
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
OR
Integrate Industrial grade controls (I/O) and monitoring with the RevPi DIO module and Ubidots; including setup for a Unit Counting App.
Project Owner Contributor
Connect your RevPi Core + RevPi DIO to Ubidots
maria-carlina-hernandezMaria Carlina Hernandez
The partner eco-system has a variety of modules to choose from:
Types of LoRa Modules are Available
undefined
This is a placeholder, because I can't get it out of my head.
Open Source Compute Module
jarrettJarrett
Pixhawk Flight Control Unit based autopilot with Raspberry Pi Computer Module 3 and all other requied sensors, modules built-in.
Drone Autopilot with Raspberry Pi CM3 .
akio-satoAkio Sato
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Raspberry Pi IOT module", please tell us the reason.
Send message
Remove Member
