KNOP record lathe + stereo cutterhead
DIY record lathe
Hi, so I wanted a record lathe but did not have the money for one. So I made one. Then I wanted to buy a stereo cutterhead but could not afford one. So I made that too.
Hi I'll try to get as much information of my lathe and cutterhead on here. I'm still continuing to improve aspects of the machine and i'll try to document the build as much as possible.
320 15 V7.skp
torque tube for 320 shank with 1,5mm dia hole opening
SSEYO Koan Play File - 127.56 kB - 11/21/2024 at 16:08
Download
320 14 V7.skp
torque tube for 320 shank with 1,4mm dia hole opening
SSEYO Koan Play File - 127.65 kB - 11/21/2024 at 16:08
Download
Suspension V3.skp
This model should be printed in polyamide using SLS or MJF. Alumide also works if you like the material. For use with a 2K S 160 A 2.0 NF dashpot from airpot.com
SSEYO Koan Play File - 4.05 MB - 12/16/2018 at 12:59
Download
Lathe_Control_New_V10.ino
Code for lathe control using Arduino Uno and TMC2100 SilentStepStick stepper motor controller. I really need to rewrite the whole thing but it works.
ino - 10.51 kB - 12/10/2018 at 14:06
Download
Cutterhead body V7 parts list .txt
All the extra materials you need to build the cutterhead.
plain - 1.08 kB - 12/10/2018 at 13:51
Download
View all 9 files
  • Things in the pipeline
    Wim Nel12/10/2018 at 14:26 0 comments
    Finish up and test new cutterhead suspension and get final 3D files online - Almost there
    Rewrite the whole code for arduino - Not started yet
    Finish up the design of 320 stylus torque tube and get final 3D files online - Waiting for parts
    Make instructions for cutterhead build and suspension build - Not started yet
    Find a way to reduce stepper motor noise during lead in / lead out - Not started yet
View project log
