320 15 V7.skptorque tube for 320 shank with 1,5mm dia hole openingSSEYO Koan Play File - 127.56 kB - 11/21/2024 at 16:08 |
320 14 V7.skptorque tube for 320 shank with 1,4mm dia hole openingSSEYO Koan Play File - 127.65 kB - 11/21/2024 at 16:08 |
Suspension V3.skpThis model should be printed in polyamide using SLS or MJF. Alumide also works if you like the material. For use with a 2K S 160 A 2.0 NF dashpot from airpot.comSSEYO Koan Play File - 4.05 MB - 12/16/2018 at 12:59 |
Lathe_Control_New_V10.inoCode for lathe control using Arduino Uno and TMC2100 SilentStepStick stepper motor controller. I really need to rewrite the whole thing but it works.ino - 10.51 kB - 12/10/2018 at 14:06 |
Cutterhead body V7 parts list .txtAll the extra materials you need to build the cutterhead.plain - 1.08 kB - 12/10/2018 at 13:51 |
Mounting adapter 1.stlFor mounting THK KR20 200mm linear slide 1mm pitch to Maytec 40mm alu profile.Standard Tesselated Geometry - 479.70 kB - 12/10/2018 at 09:22 |
Mounting adapter 2.stlFor mounting THK KR20 200mm linear slide to Manual stage TSD-403L SIGMA KOKIStandard Tesselated Geometry - 321.59 kB - 12/10/2018 at 09:22 |
Cutterhead body V7.skpThis model should be printed in polyamide using SLS or MJF. Alumide also works if you like the material.SSEYO Koan Play File - 1.21 MB - 12/10/2018 at 09:12 |
Torque tube V7 for mono stylus.skpThis model should be 3D printed in Aluminium. You need to thread the front hole (M3) and add a M3x3 crater head set screw.SSEYO Koan Play File - 141.99 kB - 12/10/2018 at 09:11 |
