Single power source
12/14/2018 at 09:13 • 0 commentsI modified the circuit to have only one power source instead of two in order to fit with the minimalism spirit. This means I now go 3D with the base ! New pictures coming up soon
Building the base
12/13/2018 at 08:25 • 0 commentsAdded mirrored circuit with one NE555 each. Power supplies are separate for now
Tree Structure
12/10/2018 at 12:56 • 0 commentsFirst step was to create the structure of the tree and add the LEDs in a garland style. This is very tricky as the structure is desoldering when trying to solder other components on it
