What got done:
- Checked power supply for outputting correct voltage unloaded and under 590 ohm power resistor load.
- Inventoried and checked over all parts in BOM.
- Planned out part locations on protoboard
- Soldered in MOSFETS as most important element in circuit
Issues:
- Small board size is good for part stability but bad for routing traces. Need to be creative with arranging high-current traces
Next steps:
- Solder on more components
- Create high-current traces by adding solder to protoboard
- Create bus for capacitor bank
- Make connectors for interchangeable work coil
jdunbar360
