Unloaded work coil oscillated at 95.2kHz with 2uF capacitance
With two more capacitors (2.64uF total) the LC tank resonated at 83kHz
9 capacitors gave 77kHz and 10 produced 71.4kHz
Frequency dropped by a few kHz with a load on the work coil
Calculated the inductance of the work coil to be 1.43uH (from capacitance-frequency measurements)
Measured current draw of induction heater from 24VDC power supply
Unloaded: 4.5A for 110W without object in work coil
Loaded with small ferrous object: current jumps to 6.4A and rises to peak at 8.3A (200W) before slowly dropping as metal object heats up
Began building MultiSim model of circuit using experimentally determined work coil inductance
Issues:
Work coil still gets excessively warm while running for longer periods of time; may lose structural integrity. We plan to solve this issue by running for short periods of time or adding fans.
Next steps:
Continue MultiSim modeling to compare theoretical to experimental results
Test other metals for their behavior in the work coil
Heating a large nut to cherry red heat using eight capacitors:
Oscilloscope measuring 2.64uF LC tank voltage (after a 10x voltage divider):
Soldered in Zener diodes, power resistors, 10K resistors
Connected MOSFETs to central negative rail
Created heavily-soldered rail for each MOSFET connection to positive
Added solder to board to buik up positive rail
Issues:
Difficult to connect copper pads with solder on board to make a continuous rail; solved by laying piece of solid-core wire across pads to facilitate connection
Extra length of resistor leads were used to bridge gaps between copper pads
Next steps:
Solder on more components
Form work coil
Create bus for capacitor bank
Make connectors for interchangeable work coil
Add power connectors
Shown below, solder trace side of board and MOSFETs:
