Fri 12-14 Progress Log
12/15/2018 at 21:58 • 0 commentsWhat got done:
- Measured frequency of LC tank with oscilloscope
- Unloaded work coil oscillated at 95.2kHz with 2uF capacitance
- With two more capacitors (2.64uF total) the LC tank resonated at 83kHz
- 9 capacitors gave 77kHz and 10 produced 71.4kHz
- Frequency dropped by a few kHz with a load on the work coil
- Calculated the inductance of the work coil to be 1.43uH (from capacitance-frequency measurements)
- Measured current draw of induction heater from 24VDC power supply
- Unloaded: 4.5A for 110W without object in work coil
- Loaded with small ferrous object: current jumps to 6.4A and rises to peak at 8.3A (200W) before slowly dropping as metal object heats up
- Began building MultiSim model of circuit using experimentally determined work coil inductance
Issues:
- Work coil still gets excessively warm while running for longer periods of time; may lose structural integrity. We plan to solve this issue by running for short periods of time or adding fans.
Next steps:
- Continue MultiSim modeling to compare theoretical to experimental results
- Test other metals for their behavior in the work coil
Heating a large nut to cherry red heat using eight capacitors:
Oscilloscope measuring 2.64uF LC tank voltage (after a 10x voltage divider):
Thurs 12-13 Progress Log
12/13/2018 at 21:50 • 0 commentsWhat got done:
- Soldered on the chokes and finished the capacitor board
- Formed the work coil and soldered it to the board
- Connected the power supply to a switch and connected it to the driver circuit
- Connected an LED to show when the circuit has power
- Did initial testing with iron, achieving roughly 1000 degrees Fahrenheit in a short period of time
Issues:
- A power supply wire pulled away from the copper clad board, meaning we had to move our circuit around a little and re-solder for sturdier connection
- Our work coil reaches very high temperatures, especially with object being heated.
- Capacitor bank gets hot with prolonged use
Next steps:
- Part-Sim theoretical testing
- Possible future testing with varied capacitance
Bottom of the circuit
Top-down view of circuit
Wed 12-12 Progress Log
12/13/2018 at 15:49 • 1 commentWhat got done:
- Soldered in fast diodes
- Disassembled premade choke assemblies to improve utility
- Bent and soldered in LC tank copper busbars (made from 14AWG solid copper wire), with connections available for work coil
- Soldered in 4 out of 6 initial capacitors for cap bank
- Sourced wire for work coil
Issues:
- Component side of board is crowded with crossed component leads; must monitor and inspect to avoid shorts
- Unconfirmed, but chokes may be wound with too thin of wire for the level of current they will be handling
Next steps:
- Solder on chokes and two more capacitors
- Form work coil and solder on
- Add power connectors
- Solder in power LED and its current-limiting resistor
- Test!
Current state of the board, with four capacitors soldered on capacitor bank:
Tues 12-11 Progress Log
12/13/2018 at 15:36 • 0 commentsWhat got done:
- Soldered in Zener diodes, power resistors, 10K resistors
- Connected MOSFETs to central negative rail
- Created heavily-soldered rail for each MOSFET connection to positive
- Added solder to board to buik up positive rail
Issues:
- Difficult to connect copper pads with solder on board to make a continuous rail; solved by laying piece of solid-core wire across pads to facilitate connection
- Extra length of resistor leads were used to bridge gaps between copper pads
Next steps:
- Solder on more components
- Form work coil
- Create bus for capacitor bank
- Make connectors for interchangeable work coil
Shown below, solder trace side of board and MOSFETs:
Mon 12-10 Progress Log
12/10/2018 at 21:35 • 0 commentsWhat got done:
- Checked power supply for outputting correct voltage unloaded and under 590 ohm power resistor load.
- Inventoried and checked over all parts in BOM.
- Planned out part locations on protoboard
- Soldered in MOSFETS as most important element in circuit
Issues:
- Small board size is good for part stability but bad for routing traces. Need to be creative with arranging high-current traces
Next steps:
- Create high-current traces by adding solder to protoboard
jdunbar360
