What got done:
- Measured frequency of LC tank with oscilloscope
- Unloaded work coil oscillated at 95.2kHz with 2uF capacitance
- With two more capacitors (2.64uF total) the LC tank resonated at 83kHz
- 9 capacitors gave 77kHz and 10 produced 71.4kHz
- Frequency dropped by a few kHz with a load on the work coil
- Calculated the inductance of the work coil to be 1.43uH (from capacitance-frequency measurements)
- Measured current draw of induction heater from 24VDC power supply
- Unloaded: 4.5A for 110W without object in work coil
- Loaded with small ferrous object: current jumps to 6.4A and rises to peak at 8.3A (200W) before slowly dropping as metal object heats up
- Began building MultiSim model of circuit using experimentally determined work coil inductance
Issues:
- Work coil still gets excessively warm while running for longer periods of time; may lose structural integrity. We plan to solve this issue by running for short periods of time or adding fans.
Next steps:
- Continue MultiSim modeling to compare theoretical to experimental results
- Test other metals for their behavior in the work coil
Heating a large nut to cherry red heat using eight capacitors:
Oscilloscope measuring 2.64uF LC tank voltage (after a 10x voltage divider):
