We continued to solder our circuit onto the final breadboard. We finished the heat-sensitive section of the fire detector, then moved on to the two relays and the AC source circuit for the loudspeaker. Our goal is to fit both relays, the transducer, and the three circuit sections on the same breadboard. We only succeeded in wiring up both relays, so tomorrow we plan to wire up the circuit which powers the transducer.
