1AskSensors Signing Up
Get a free account.
2Sensor Setup
Sign In and create a Sensor to send data to. Here is a getting started tutorial.
Copy down your API KEY IN. -
3Write the code
Download the code from github, Set your WiFi details and your Sensor API Key In
4Run the code
Build the code using Arduino IDE.
Plug your ESP32 and upload the code from Arduino IDE.
I suppose that you have already set your arduino IDE to program ESP32 with. if not done yet, please refer to this article. -
5Visualize data
Go to your sensor dashboard and visualize your data in real time.
