Fading labels
12/13/2018 at 05:19 • 0 commentsSo the main issue with laser printed labels is that the table paper is fairly thing and I suspect that prevents the toner from fusing properly. This leads to the pixels essentially falling off the label.
This just wont do for an inventory system. Luckily I can across a nice cheap label printer, the Dymo LabelManager® PnP ($35 on amazon at time of writing). Next step was to make it print usable labels.
The printer seems to have two modes, and for it to work with the Linux driver I had to follow a really useful set of instructions here: http://draisberghof.de/usb_modeswitch/bb/viewtopic.php?f=3&t=947
After that, it was just a matter of getting pixel accurate prints from this printer. I printed a set of test prints generated in inkscape to count measure the performance and settings of the printer:The steps I followed where (from bottom up:
- generate a diagonal and count the steps
- use shallower angles to get a better count
- once I have a good guess create test print with 1-3 pixel and 1-3 pixel gaps as well as diagonals
- realise that the vector printing worked awful and the bitmap with high DPI worked better
- tune in the DPI and the exact pixel counts by seeing how much of the test pattern was cut off
- print extreme stress with a pixel size checkerboard
- print a new test pattern with the wrong settings
- print it again with the right settings and realise there where still missing pixels
- the printer has 64 pixels and the lead to a DPI of 540
- print the test print with DPI of 540 and we have a perfect print :)
I will have the template inkscape file uploaded somewhere with the pixel boundary marked by the grid. The fiel should be printed with a bitmap rendering at 540 DPI.
#!/bin/bash for i in $(seq -f "%05g" 0 20) do qrencode -s 3 -m 0 -t PNG $i -o $i.png convert $i.png -gravity East -splice 129x0 -font Helvetica-Narrow -pointsize 52 -annotate +0+0 $i $i.png echo $i done montage *.png -tile 1x -geometry '+0+24>' page.pdf convert page.pdf -units PixelsPerInch -density 540 page.pdf #to print lpr page.pdfThe above script generates the QR codes and then sends them straight to the label printer with the help of CUPS.
And here we have durable new labels :D
Labels
12/13/2018 at 04:49 • 0 commentsSo the first order of business is to label every box. The start of a proper inventory. The first idea I had where the stick sheets of A4 labels. You put these through a printer, slice it up and BAM, custom stickers. So a quick shell scripts later we have:
#!/bin/bash for i in $(seq -f "%05g" 0 703) do qrencode $i -o $i.png convert $i.png -gravity East -splice 100x0 -pointsize 20 -annotate +20+0 $i $i.png echo $i done montage *.png -tile 16x -geometry '+3+3>' page.pdf convert page.pdf -units PixelsPerInch -density 400 page.pdf![]()
This was printed out and a scalpel + patience resulted in:
These boxes along with a small jig was able to read the QR codes and take photos of the box contents.
JLAM
