This is a discreet four bit adder I designed and constructed using 60 RTL NAND gates.
All the gates are designed using RTL (transistor resistor logic). In order to keep the transistor count down, the adders use positive and floating signals rather than the traditional positive and negative signals used in digital electronics. This allows the board to use 2/5ths of the digital transistor count.
ARITH-MATIC
TomKeddie
Astronomermike
Adrian Freed
