Lion core for MiSTer
A project log for Lion FPGA CPU/Computer
A 16-bit (and a 32bit) FPGA CPU I call Lion CPU and a computer, the Lion computer. Everything built from scratch.
leonLeon 03/24/2020 at 20:301 Comment
A friend lend me his MiSTer board and as I had a lot of time because of  various restrictions due to corona virus (here in Greece) I ported Lion to the mister board.
Most things work well but there are some differences in keyboard behaviour and so to play the games well you need a usb joystick, also there is no serial port and XY-Display support as in the original Lion.
VGA output is a bit dark and redish I don't know why. (now fixed)
HDMI is better but both outputs are darker than in the real Lion computer (now fixed).
You can find the core in a zip file at the files section.
Jamie Dickson wrote 03/28/2020 at 12:37 point
Hello, cool project! Is the source code available somewhere so we can make improvements in interacting with the MiSTer framework?
