Overview video:
Turn a Super Nintendo Controller into a self-contained TV Plug-n-Play console
Overview video:
sns-005z wiring.pngWiring DiagramPortable Network Graphics (PNG) - 1.01 MB - 10/12/2016 at 14:14 |
You'll need the following components to make this project.
Since we are using an official SNES controller as a base we get to reuse the controller circuit board directly for 2 reasons...
To prep for this we only need to make one change - remove the existing wiring harness + cable
First remove the cable from the harness
Then desolder these 5 pins from the front of the circuit board
Once done you should be able remove the white harness with a set of pliers so the board ends up looking like this...
Next we are going to make some modifications to the bottom and top of the case so we can start laying out the components and testing placement+fit
The bottom of the controller case has a few posts that need to be removed to allow the Raspberry Pi Zero, Powerboost and Battery to fit
Remove these highlighted posts...
A set of pliers should do the trick
Once all are removed you can smooth down the excess with sandpaper
After sanding things down the bottom of the controller should look something like this...
Next we'll make cuts in the case for the HDMI cable, power switch and usb charing port
Did you have to programme the zero to use headers like a USB
can you help me figure out the whole programing. i think i have everthing right but not sure how to get the pi the read the control.
