Finished the chassis
A project log for Freeform robot
A simple robot built from wire
robsoncoutoRobsonCouto 12/19/2018 at 22:210 Comments
Finished soldering together the basic structure of the robot. I used magnet wire for the structure, which is coated with a thin layer of insulating material. I used a file or a razor knife to remove this material where the wires are soldered together.
