The trick with the tracker is to use a spherecam on USB, but opencv can't deterministically select the same camera, scale the input, & display in fullscreen mode on a mac.
There is running a network client on virtualbox to handle all the I/O or fixing opencv. Running a network client in a virtual machine to fix the real machine is ridiculous, so the decision was made to fix opencv, uninstall the brew version of opencv & recompile it, caffe, & openpose again from scratch.
brew remove opencv
Openpose on the mac can't link to a custom opencv. You have to hack some cmake files or just link it manually.
Discovered openpose depends heavily on the aspect ratio & lens projection. It works much faster but detects fewer poses on a 1x1 aspect ratio. It works much slower & detects more poses on a 16x9 crop of the center. It works much slower on 512x512 & much faster on 480x480. Pillarboxing & stretching to fit the entire projection in 16x9 don't work.
Spherical projections are as good as equirectangular projections. The trick is detecting directly above & below with the 16x9 cropping. It's not going to detect someone looking down on it like the Facebook portal, but the current application doesn't need to see directly above & below. There's also scanning each frame in 2 passes.
Despite paying a fortune to ship an ESCAM Q8 from China in 7 days, it was put on the same boat as the free shipping, 2 weeks ago.
lion mclionhead
