The pose classifier eventually was bulletproof. This system had already dramatically improved the workout despite all its glitches. You know it's a game changer because no-one watches the video. Just like marriage & politics, the most mundane gadgets no-one cares about are the most revolutionary while the most exciting gadgets everyone wants are the least revolutionary.
The mane problem became connectivity. Lockups lasting several minutes & periods of many dropped frames continued. It seemed surmountable compared to the machine vision. Finally did the long awaited router upgrade.
Its days of computing ended 6 years ago. It is now the apartment complex's most powerful router. Seem to recall this was the laptop lions used while dating ... the single women. Lions wrote firmware on it while the single women watched TV or ate their doritos.
The other problem was for the pose classifier to work, it can't drop any frames. The tablet needs to capture only as many frames as the GPU can handle & the GPU needs to process all of them. Relying on the GPU to drop frames caused it to drop a lot of poses when a large number of frames got buffered & received in the time span of processing a single frame.
The hunt for connectivity eventually led to wifi not being fast enough to send JPEG frames both ways, at 6fps. The reason skype can send video 2 ways is H.264, which entails a native build of x264 so isn't worth it for this program. Wifi is also bad at multiplexing 2 way traffic. Slightly better results came from synchronizing the frame readbacks, but only after eliminating them completely did the rep counts have no delay & the lost connections go away. It counted instantaneously, even on the ancient broken tablet, but it didn't look as good without the openpose outlines. There's also bluetooth for frame readbacks or drawing vectors & statistics on the tablet, if H.264 is that bad.
