How to design an 8 bit star tree topper in Fusion 360.
Our image doesn’t have the correct dimensions associated with it so we’ll need to calibrate it. Under the Browser located on the left side of the screen you’ll see a folder name Canvas. Click on the triangle on the left side of the folder to expand and you’ll see our canvass - My8BitStar. Right click on My8BitStar and select Calibrate. To calibrate click on the bottom left corner of the image to place the first point. Then left click on the top left corner of the image to place the second point. We want this distance to be 160mm so enter 160 into the dialog box and hit enter. This will scale the image to 160mm vertically. Zoom out to fit entire canvas on screen.
