You know you want to make some air-line coax for an impedance reference from brass hobby tubing. But, what sizes to use? I threw together a quick python script to find the characteristic impedance and cutoff frequencies for all the combinations.
The script uses all the available sizes (metric and inch) of K&S brass tubing. Some sizes are also available in copper, and any of them could be silver plated, although this probably isn't necessary for short sections.
I haven't built any coax this way yet, but now I know which sizes to select.
Calculations
The characteristic impedance of coax is given by:
where D is the inner diameter of the outer conductor, and d is the outer diameter of the inner conductor. The diameter units cancel.
Cutoff Frequency
At lower frequencies, waves travel in coax in the so-called transverse electromagnetic mode (TEM), where the electric and magnetic fields are both perpendicular to the direction of travel (i.e. the coax). Above a certain frequency, called the cutoff, higher-order modes can also exist on the cable. These propagate at different speeds, and generally ruin your day.
The cutoff frequency for coax is given by:
with D and d in inches.
In both cases, the code uses Er = 1.00058986, the value for air.
Code
The python code calculates the characteristic impedance and cutoff frequency for all the combinations of K&R tubing sizes:
#!/usr/bin/env python3
import numpy as np
from fractions import Fraction
# (name, OD, ID) inches
US_idx = np.linspace(1, 21, 21)
US_tubing = map(lambda x: (str(Fraction(int(x), 32))+'"',
x/32, x/32 - 0.028), US_idx)
mm_idx1 = [1, 1.5, 2, 3, 3.5, 4, 4.5, 5]
mm_idx2 = [2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13]
mm_tubing1 = map(lambda x: (str(x) + '/0.225 mm', x/25.4, (x-2*0.225)/25.4), mm_idx1)
mm_tubing2 = map(lambda x: (str(x) + '/0.45 mm', x/25.4, (x-2*0.45)/25.4), mm_idx2)
tubing = list(US_tubing) + list( mm_tubing1) + list(mm_tubing2)
Er = 1.00058986
table = []
print(' Inner Outer Cutoff Z0')
print(' (GHz) (Ohm)')
print('--------------------------------------------')
for outer in tubing:
for inner in tubing:
if inner[1] >= outer[2]:
continue
Z0 = 138 * np.log10(outer[2]/inner[1])/np.sqrt(Er)
fc = 7.51393 / ((inner[1] + outer[2])*np.sqrt(Er))
table.append((inner[0], outer[0], fc, Z0))
for i in sorted(table, key=lambda x: x[3]):
print('{:>12s} {:>12s} {:5.1f} {:6.2f}'.format(i[0], i[1], i[2], i[3]))
Table
Here are the results. For the really low-Z combinations, although the tubing would fit based on the nominal sizes, it would probably short out due to manufacturing tolerances.
Inner Outer Cutoff Z0 (GHz) (Ohm) -------------------------------------------- 8/0.45 mm 11/32" 11.9 0.15 5/8" 21/32" 6.0 0.31 19/32" 5/8" 6.3 0.33 9/16" 19/32" 6.7 0.35 17/32" 9/16" 7.0 0.37 1/2" 17/32" 7.5 0.39 15/32" 1/2" 8.0 0.41 7/16" 15/32" 8.6 0.44 13/32" 7/16" 9.2 0.48 12/0.45 mm 13/0.45 mm 7.9 0.50 3/8" 13/32" 10.0 0.52 11/0.45 mm 12/0.45 mm 8.6 0.54 11/32" 3/8" 10.9 0.56 10/0.45 mm 11/0.45 mm 9.5 0.60 5/16" 11/32" 12.0 0.62 4.5/0.225 mm 5/0.225 mm 21.1 0.66 9/0.45 mm 10/0.45 mm 10.5 0.66 9/32" 5/16" 13.3 0.69 4/0.225 mm 4.5/0.225 mm 23.7 0.74 4/0.45 mm 4.5/0.225 mm 23.7 0.74 8/0.45 mm 9/0.45 mm 11.9 0.74 4/0.225 mm 3/16" 23.7 0.76 4/0.45 mm 3/16" 23.7 0.76 1/4" 9/32" 14.9 0.77 3.5/0.225 mm 4/0.225 mm 27.1 0.85 7/0.45 mm 8/0.45 mm 13.5 0.85 7/32" 1/4" 17.0 0.88 15/32" 13/0.45 mm 7.9 0.97 3/0.225 mm 3.5/0.225 mm 31.5 0.99 3/0.45 mm 3.5/0.225 mm 31.5 0.99 6/0.45 mm 7/0.45 mm 15.8 0.99 3/16" 7/32" 19.9 1.03 11/0.45 mm 15/32" 8.6 1.05 5/0.225 mm 6/0.45 mm 18.9 1.19 5/0.45 mm 6/0.45 mm 18.9 1.19 5/32" 4.5/0.225 mm 23.8 1.21 5/16" 9/0.45 mm 11.9 1.21 5/32" 3/16" 23.8 1.23 4/0.225 mm 5/0.45 mm 23.6 1.48 4/0.45 mm 5/0.45 mm 23.6 1.48 1/8" 5/32" 29.7 1.54 7/0.45 mm 5/16" 13.4 1.91 5/32" 5/0.45 mm 23.6 1.95 1.5/0.225 mm 2/0.225 mm 62.6 1.96 3/0.225 mm 4/0.45 mm 31.3 1.96 3/0.45 mm 4/0.45 mm 31.3 1.96 3/32" 1/8" 39.4 2.04 10/0.45 mm 7/16" 9.4 2.36 11/32" 10/0.45 mm 10.7 2.48 13/0.45 mm 9/16" 7.2 2.60 1/0.225 mm 1.5/0.225 mm 93.1 2.92 2/0.225 mm 3/0.45 mm 46.5 2.92 2/0.45 mm 3/0.45 mm 46.5 2.92 1/16" 3/32" 58.6 3.04 19/32" 21/32" 6.1 3.38 3/8" 11/0.45 mm 9.7 3.51 9/16" 5/8" 6.5 3.57 17/32" 19/32" 6.8 3.77 12/0.45 mm 17/32" 7.7 3.79 9/0.45 mm 13/32" 10.3 3.91 1/2" 9/16" 7.3 4.00 3/32" 3/0.225 mm 38.7 4.10 3/16" 6/0.45 mm 19.3 4.10 6/0.45 mm 9/32" 15.3 4.17 15/32" 17/32" 7.7 4.26 13/32" 12/0.45 mm 8.9 4.37 4.5/0.225 mm 7/32" 20.4 4.43 7/16" 1/2" 8.3 4.55 13/32" 15/32" 8.9 4.88 3/0.225 mm 5/32" 30.5 4.93 3/0.45 mm 5/32" 30.5 4.93 7/16" 13/0.45 mm 8.2 5.10 11/0.45 mm 1/2" 8.3 5.16 3/8" 7/16" 9.6 5.27 7/32" 7/0.45 mm 16.4 5.59 11/0.45 mm 13/0.45 mm 8.3 5.71 1/0.225 mm 2/0.45 mm 90.9 5.71 11/32" 13/32" 10.4 5.73 8/0.45 mm 3/8" 11.3 5.80 1/32" 1/16" 114.2 5.93 13/0.45 mm 19/32" 7.0 6.00 10/0.45 mm 12/0.45 mm 9.0 6.25 5/16" 3/8" 11.4 6.27 1.5/0.225 mm 3/32" 60.2 6.43 9/16" 21/32" 6.3 6.62 1/8" 4/0.225 mm 28.4 6.69 1/4" 8/0.45 mm 14.2 6.69 10/0.45 mm 15/32" 9.0 6.76 9/0.45 mm 11/0.45 mm 10.0 6.91 9/32" 11/32" 12.6 6.93 17/32" 5/8" 6.7 6.99 5/0.225 mm 1/4" 17.9 7.20 5/0.45 mm 1/4" 17.9 7.20 12/0.45 mm 9/16" 7.5 7.39 1/2" 19/32" 7.0 7.40 4.5/0.225 mm 6/0.45 mm 19.9 7.50 9/32" 9/0.45 mm 12.5 7.53 4/0.225 mm 5/0.225 mm 22.3 7.72 4/0.45 mm 5/0.225 mm 22.3 7.72 8/0.45 mm 10/0.45 mm 11.2 7.72 1/4" 5/16" 14.1 7.75 15/32" 9/16" 7.5 7.86 7/0.45 mm 11/32" 12.7 8.15 5/32" 5/0.225 mm 22.4 8.19 5/16" 10/0.45 mm 11.2 8.19 7/16" 17/32" 8.0 8.39 9/0.45 mm 7/16" 9.8 8.67 11/32" 11/0.45 mm 10.1 8.73 3.5/0.225 mm 4.5/0.225 mm 25.3 8.74 7/0.45 mm 9/0.45 mm 12.6 8.74 3.5/0.225 mm 3/16" 25.3 8.76 7/32" 9/32" 15.9 8.77 13/32" 1/2" 8.6 8.99 11/0.45 mm 17/32" 8.0 9.00 3/8" 12/0.45 mm 9.3 9.17 13/0.45 mm 5/8" 6.8 9.22 3.5/0.225 mm 5/0.45 mm 25.1 9.48 13/32" 13/0.45 mm 8.5 9.54 3/8" 15/32" 9.2 9.68 17/32" 21/32" 6.5 10.05 3/0.225 mm 4/0.225 mm 29.1 10.09 3/0.45 mm 4/0.225 mm 29.1 10.09 6/0.45 mm 8/0.45 mm 14.6 10.09 3/16" 1/4" 18.3 10.12 11/32" 7/16" 10.0 10.49 1/2" 5/8" 6.8 10.62 12/0.45 mm 19/32" 7.2 10.80 10/0.45 mm 1/2" 8.7 10.87 8/0.45 mm 13/32" 10.8 10.97 6/0.45 mm 5/16" 14.4 11.14 15/32" 19/32" 7.3 11.27 10/0.45 mm 13/0.45 mm 8.6 11.42 5/16" 13/32" 10.9 11.44 4/0.225 mm 7/32" 21.6 11.48 4/0.45 mm 7/32" 21.6 11.48 5/0.225 mm 7/0.45 mm 17.2 11.91 5/0.45 mm 7/0.45 mm 17.2 11.91 5/32" 7/32" 21.6 11.95 7/16" 9/16" 7.7 12.00 13/0.45 mm 21/32" 6.6 12.28 2/0.225 mm 1/8" 42.7 12.50 2/0.45 mm 1/8" 42.7 12.50 9/0.45 mm 12/0.45 mm 9.5 12.57 9/32" 3/8" 12.0 12.59 11/0.45 mm 9/16" 7.8 12.61 13/32" 17/32" 8.3 12.83 9/0.45 mm 15/32" 9.4 13.08 4.5/0.225 mm 1/4" 18.8 13.52 1/2" 21/32" 6.7 13.68 3/8" 1/2" 8.9 13.78 7/0.45 mm 3/8" 12.1 13.80 8/0.45 mm 11/0.45 mm 10.5 13.97 1/4" 11/32" 13.3 13.99 12/0.45 mm 5/8" 7.0 14.02 3/8" 13/0.45 mm 8.8 14.34 11/32" 12/0.45 mm 9.6 14.38 5/16" 11/0.45 mm 10.6 14.44 15/32" 5/8" 7.0 14.49 9/32" 10/0.45 mm 11.7 14.50 2/0.225 mm 3/0.225 mm 41.9 14.56 2/0.45 mm 3/0.225 mm 41.9 14.56 4/0.225 mm 6/0.45 mm 21.0 14.56 4/0.45 mm 6/0.45 mm 21.0 14.56 1/8" 4.5/0.225 mm 26.4 14.58 1/4" 9/0.45 mm 13.2 14.58 1/8" 3/16" 26.4 14.60 7/32" 8/0.45 mm 15.1 14.69 10/0.45 mm 17/32" 8.4 14.71 3/32" 3.5/0.225 mm 35.1 14.83 3/16" 7/0.45 mm 17.6 14.83 11/32" 15/32" 9.6 14.89 5/32" 6/0.45 mm 21.0 15.03 5/0.225 mm 9/32" 16.7 15.09 5/0.45 mm 9/32" 16.7 15.09 1/8" 5/0.45 mm 26.2 15.32 7/16" 19/32" 7.5 15.40 3.5/0.225 mm 5/0.225 mm 23.7 15.72 7/0.45 mm 10/0.45 mm 11.9 15.72 8/0.45 mm 7/16" 10.4 15.73 7/32" 5/16" 14.9 15.75 3/32" 4/0.45 mm 34.8 15.80 11/0.45 mm 19/32" 7.5 16.01 5/16" 7/16" 10.4 16.20 13/32" 9/16" 8.0 16.44 1/32" 1.5/0.225 mm 103.5 16.76 1/16" 3/0.45 mm 51.7 16.76 12/0.45 mm 21/32" 6.8 17.08 9/0.45 mm 1/2" 9.1 17.18 6/0.45 mm 11/32" 13.6 17.39 15/32" 21/32" 6.8 17.55 3/8" 17/32" 8.6 17.62 9/0.45 mm 13/0.45 mm 9.0 17.73 9/32" 13/32" 11.4 17.75 3/0.225 mm 4.5/0.225 mm 27.1 17.98 3/0.45 mm 4.5/0.225 mm 27.1 17.98 6/0.45 mm 9/0.45 mm 13.5 17.98 3/0.225 mm 3/16" 27.1 18.00 3/0.45 mm 3/16" 27.1 18.00 3/16" 9/32" 17.0 18.01 4.5/0.225 mm 7/0.45 mm 18.0 18.23 10/0.45 mm 9/16" 8.1 18.32 7/16" 5/8" 7.3 18.62 3/0.225 mm 5/0.45 mm 26.9 18.72 3/0.45 mm 5/0.45 mm 26.9 18.72 3/32" 5/32" 33.8 18.77 7/0.45 mm 13/32" 11.5 18.97 11/32" 1/2" 9.2 19.00 11/0.45 mm 5/8" 7.3 19.23 3.5/0.225 mm 7/32" 22.9 19.48 11/32" 13/0.45 mm 9.2 19.55 1/32" 2/0.45 mm 100.8 19.55 8/0.45 mm 12/0.45 mm 10.0 19.62 1/4" 3/8" 12.6 19.64 13/32" 19/32" 7.7 19.84 5/16" 12/0.45 mm 10.0 20.09 8/0.45 mm 15/32" 9.9 20.13 1.5/0.225 mm 3/0.45 mm 53.0 20.16 4/0.225 mm 1/4" 19.8 20.57 4/0.45 mm 1/4" 19.8 20.57 5/16" 15/32" 10.0 20.60 9/32" 11/0.45 mm 11.1 20.75 5/0.225 mm 8/0.45 mm 15.8 21.01 5/0.45 mm 8/0.45 mm 15.8 21.01 9/0.45 mm 17/32" 8.8 21.02 5/32" 1/4" 19.9 21.04 3/8" 9/16" 8.3 21.23 4.5/0.225 mm 9/32" 17.5 21.41 1/8" 5/0.225 mm 24.7 21.56 1/4" 10/0.45 mm 12.3 21.56 7/16" 21/32" 7.0 21.68 10/0.45 mm 19/32" 7.8 21.72 7/0.45 mm 11/0.45 mm 11.2 21.97 7/32" 11/32" 14.1 21.99 5/0.225 mm 5/16" 15.6 22.07 5/0.45 mm 5/16" 15.6 22.07 11/0.45 mm 21/32" 7.1 22.29 9/32" 7/16" 10.9 22.51 3.5/0.225 mm 6/0.45 mm 22.2 22.56 7/32" 9/0.45 mm 14.0 22.58 11/32" 17/32" 8.9 22.84 6/0.45 mm 3/8" 12.9 23.04 13/32" 5/8" 7.5 23.06 7/0.45 mm 7/16" 11.0 23.73 3/32" 4/0.225 mm 32.2 23.93 3/16" 8/0.45 mm 16.1 23.93 8/0.45 mm 1/2" 9.5 24.24 9/0.45 mm 9/16" 8.5 24.63 3/8" 19/32" 8.0 24.64 5/16" 1/2" 9.6 24.71 8/0.45 mm 13/0.45 mm 9.5 24.79 1/4" 13/32" 12.0 24.81 10/0.45 mm 5/8" 7.6 24.94 3/0.225 mm 5/0.225 mm 25.3 24.96 3/0.45 mm 5/0.225 mm 25.3 24.96 6/0.45 mm 10/0.45 mm 12.6 24.96 3/16" 5/16" 15.9 24.98 5/16" 13/0.45 mm 9.5 25.26 2/0.225 mm 3.5/0.225 mm 37.8 25.28 2/0.45 mm 3.5/0.225 mm 37.8 25.28 4/0.225 mm 7/0.45 mm 18.9 25.28 4/0.45 mm 7/0.45 mm 18.9 25.28 1/8" 7/32" 23.8 25.32 5/32" 7/0.45 mm 18.9 25.75 13/32" 21/32" 7.3 26.12 1/0.225 mm 2/0.225 mm 74.8 26.26 2/0.225 mm 4/0.45 mm 37.4 26.26 2/0.45 mm 4/0.45 mm 37.4 26.26 1/16" 1/8" 47.1 26.34 9/32" 12/0.45 mm 10.5 26.40 11/32" 9/16" 8.6 26.45 9/32" 15/32" 10.4 26.92 4.5/0.225 mm 8/0.45 mm 16.4 27.32 7/0.45 mm 12/0.45 mm 10.5 27.62 7/32" 3/8" 13.3 27.64 1/4" 11/0.45 mm 11.6 27.81 3/8" 5/8" 7.7 27.86 10/0.45 mm 21/32" 7.4 28.00 9/0.45 mm 19/32" 8.2 28.04 8/0.45 mm 17/32" 9.2 28.08 7/0.45 mm 15/32" 10.5 28.13 6/0.45 mm 13/32" 12.2 28.21 5/0.225 mm 11/32" 14.7 28.31 5/0.45 mm 11/32" 14.7 28.31 4.5/0.225 mm 5/16" 16.3 28.38 1/16" 3/0.225 mm 46.1 28.40 1/8" 6/0.45 mm 23.1 28.40 4/0.225 mm 9/32" 18.3 28.46 4/0.45 mm 9/32" 18.3 28.46 5/16" 17/32" 9.2 28.55 3.5/0.225 mm 1/4" 20.9 28.57 3/0.225 mm 7/32" 24.3 28.72 3/0.45 mm 7/32" 24.3 28.72 5/0.225 mm 9/0.45 mm 14.6 28.90 5/0.45 mm 9/0.45 mm 14.6 28.90 5/32" 9/32" 18.3 28.93 2/0.225 mm 5/32" 36.3 29.23 2/0.45 mm 5/32" 36.3 29.23 7/32" 10/0.45 mm 13.0 29.56 1/4" 7/16" 11.4 29.57 1.5/0.225 mm 1/8" 48.1 29.73 11/32" 19/32" 8.3 29.85 1/0.225 mm 3/32" 71.5 30.73 3/8" 21/32" 7.5 30.92 9/32" 1/2" 10.0 31.02 6/0.45 mm 11/0.45 mm 11.9 31.20 3/16" 11/32" 14.9 31.23 9/0.45 mm 5/8" 7.9 31.26 9/32" 13/0.45 mm 9.9 31.57 8/0.45 mm 9/16" 8.8 31.69 1.5/0.225 mm 3/0.225 mm 47.1 31.79 3/0.225 mm 6/0.45 mm 23.6 31.79 3/0.45 mm 6/0.45 mm 23.6 31.79 3/32" 4.5/0.225 mm 29.7 31.82 3/16" 9/0.45 mm 14.8 31.82 3/32" 3/16" 29.7 31.84 5/16" 9/16" 8.9 32.16 7/0.45 mm 1/2" 10.0 32.24 3/32" 5/0.45 mm 29.4 32.56 7/0.45 mm 13/0.45 mm 10.0 32.79 7/32" 13/32" 12.6 32.81 6/0.45 mm 7/16" 11.6 32.96 11/32" 5/8" 8.0 33.07 3.5/0.225 mm 7/0.45 mm 19.9 33.28 1/4" 12/0.45 mm 10.9 33.46 5/0.225 mm 3/8" 13.8 33.96 5/0.45 mm 3/8" 13.8 33.96 1/4" 15/32" 10.9 33.97 9/0.45 mm 21/32" 7.6 34.31 2/0.225 mm 4/0.225 mm 34.4 34.38 2/0.45 mm 4/0.225 mm 34.4 34.38 4/0.225 mm 8/0.45 mm 17.2 34.38 4/0.45 mm 8/0.45 mm 17.2 34.38 1/8" 1/4" 21.6 34.41 4.5/0.225 mm 11/32" 15.2 34.62 5/32" 8/0.45 mm 17.2 34.85 9/32" 17/32" 9.6 34.86 8/0.45 mm 19/32" 8.5 35.09 4.5/0.225 mm 9/0.45 mm 15.1 35.22 4/0.225 mm 5/16" 17.0 35.44 4/0.45 mm 5/16" 17.0 35.44 5/16" 19/32" 8.6 35.56 7/32" 11/0.45 mm 12.2 35.81 5/0.225 mm 10/0.45 mm 13.5 35.88 5/0.45 mm 10/0.45 mm 13.5 35.88 5/32" 5/16" 17.0 35.91 7/0.45 mm 17/32" 9.6 36.08 11/32" 21/32" 7.7 36.13 3.5/0.225 mm 9/32" 19.2 36.46 6/0.45 mm 12/0.45 mm 11.2 36.86 3/16" 3/8" 14.1 36.88 6/0.45 mm 15/32" 11.1 37.37 7/32" 7/16" 12.0 37.57 3/0.225 mm 1/4" 22.1 37.81 3/0.45 mm 1/4" 22.1 37.81 1/4" 1/2" 10.4 38.08 8/0.45 mm 5/8" 8.2 38.31 9/32" 9/16" 9.2 38.47 1/4" 13/0.45 mm 10.3 38.63 5/16" 5/8" 8.3 38.78 3/32" 5/0.225 mm 27.5 38.80 3/16" 10/0.45 mm 13.8 38.80 1/16" 3.5/0.225 mm 41.1 39.12 1/8" 7/0.45 mm 20.6 39.12 5/0.225 mm 13/32" 13.1 39.13 5/0.45 mm 13/32" 13.1 39.13 7/0.45 mm 9/16" 9.3 39.69 1/32" 2/0.225 mm 81.4 40.10 1/16" 4/0.45 mm 40.7 40.10 4.5/0.225 mm 3/8" 14.3 40.28 8/0.45 mm 21/32" 8.0 41.37 7/32" 12/0.45 mm 11.5 41.46 6/0.45 mm 1/2" 10.6 41.47 4/0.225 mm 11/32" 15.9 41.68 4/0.45 mm 11/32" 15.9 41.68 5/16" 21/32" 8.0 41.84 9/32" 19/32" 8.9 41.88 1/4" 17/32" 10.0 41.92 7/32" 15/32" 11.4 41.97 6/0.45 mm 13/0.45 mm 10.5 42.03 3/16" 13/32" 13.3 42.05 5/0.225 mm 11/0.45 mm 12.6 42.13 5/0.45 mm 11/0.45 mm 12.6 42.13 5/32" 11/32" 15.9 42.15 4.5/0.225 mm 10/0.45 mm 14.0 42.19 2/0.225 mm 4.5/0.225 mm 31.5 42.27 2/0.45 mm 4.5/0.225 mm 31.5 42.27 4/0.225 mm 9/0.45 mm 15.8 42.27 4/0.45 mm 9/0.45 mm 15.8 42.27 2/0.225 mm 3/16" 31.5 42.29 2/0.45 mm 3/16" 31.5 42.29 1/8" 9/32" 19.9 42.30 3.5/0.225 mm 8/0.45 mm 18.0 42.38 1.5/0.225 mm 3.5/0.225 mm 41.9 42.52 3/0.225 mm 7/0.45 mm 21.0 42.52 3/0.45 mm 7/0.45 mm 21.0 42.52 3/32" 7/32" 26.4 42.56 5/32" 9/0.45 mm 15.8 42.74 2/0.225 mm 5/0.45 mm 31.3 43.01 2/0.45 mm 5/0.45 mm 31.3 43.01 1/16" 5/32" 39.4 43.07 7/0.45 mm 19/32" 8.9 43.09 3.5/0.225 mm 5/16" 17.8 43.44 1.5/0.225 mm 4/0.45 mm 41.5 43.49 5/0.225 mm 7/16" 12.4 43.89 5/0.45 mm 7/16" 12.4 43.89 1/0.225 mm 3/0.45 mm 61.5 44.45 1/32" 3/32" 77.4 44.57 3/16" 11/0.45 mm 12.8 45.04 9/32" 5/8" 8.6 45.10 6/0.45 mm 17/32" 10.2 45.31 4.5/0.225 mm 13/32" 13.5 45.44 1/4" 9/16" 9.6 45.53 3/32" 6/0.45 mm 25.5 45.63 3/0.225 mm 9/32" 20.2 45.70 3/0.45 mm 9/32" 20.2 45.70 7/32" 1/2" 10.9 46.08 7/0.45 mm 5/8" 8.6 46.31 1.5/0.225 mm 5/32" 40.1 46.46 7/32" 13/0.45 mm 10.8 46.63 3/16" 7/16" 12.6 46.80 4/0.225 mm 3/8" 14.9 47.33 4/0.45 mm 3/8" 14.9 47.33 5/0.225 mm 12/0.45 mm 11.9 47.78 5/0.45 mm 12/0.45 mm 11.9 47.78 5/32" 3/8" 14.9 47.80 9/32" 21/32" 8.3 48.15 1/16" 4/0.225 mm 37.1 48.22 1/8" 8/0.45 mm 18.6 48.22 5/0.225 mm 15/32" 11.8 48.29 5/0.45 mm 15/32" 11.8 48.29 4.5/0.225 mm 11/0.45 mm 13.1 48.44 6/0.45 mm 9/16" 9.7 48.92 1/4" 19/32" 9.2 48.93 2/0.225 mm 5/0.225 mm 29.1 49.25 2/0.45 mm 5/0.225 mm 29.1 49.25 4/0.225 mm 10/0.45 mm 14.6 49.25 4/0.45 mm 10/0.45 mm 14.6 49.25 1/8" 5/16" 18.3 49.28 7/0.45 mm 21/32" 8.3 49.37 3.5/0.225 mm 11/32" 16.6 49.68 5/32" 10/0.45 mm 14.6 49.72 7/32" 17/32" 10.4 49.92 4.5/0.225 mm 7/16" 12.8 50.20 3.5/0.225 mm 9/0.45 mm 16.4 50.27 3/16" 12/0.45 mm 12.0 50.70 3/16" 15/32" 12.0 51.21 1.5/0.225 mm 4/0.225 mm 37.8 51.62 3/0.225 mm 8/0.45 mm 18.9 51.62 3/0.45 mm 8/0.45 mm 18.9 51.62 3/32" 1/4" 23.8 51.65 1/4" 5/8" 8.9 52.15 6/0.45 mm 19/32" 9.4 52.33 5/0.225 mm 1/2" 11.2 52.40 5/0.45 mm 1/2" 11.2 52.40 4/0.225 mm 13/32" 14.0 52.50 4/0.45 mm 13/32" 14.0 52.50 3/0.225 mm 5/16" 18.7 52.67 3/0.45 mm 5/16" 18.7 52.67 5/0.225 mm 13/0.45 mm 11.2 52.95 5/0.45 mm 13/0.45 mm 11.2 52.95 5/32" 13/32" 14.1 52.97 2/0.225 mm 7/32" 27.9 53.01 2/0.45 mm 7/32" 27.9 53.01 7/32" 9/16" 10.0 53.53 1/0.225 mm 1/8" 55.1 54.03 4.5/0.225 mm 12/0.45 mm 12.2 54.10 4.5/0.225 mm 15/32" 12.2 54.61 1/4" 21/32" 8.6 55.21 3/16" 1/2" 11.4 55.31 3.5/0.225 mm 3/8" 15.5 55.33 4/0.225 mm 11/0.45 mm 13.5 55.50 4/0.45 mm 11/0.45 mm 13.5 55.50 1/8" 11/32" 17.0 55.52 6/0.45 mm 5/8" 9.0 55.55 3/16" 13/0.45 mm 11.3 55.87 5/32" 11/0.45 mm 13.6 55.97 1/0.225 mm 3/0.225 mm 53.7 56.09 2/0.225 mm 6/0.45 mm 26.9 56.09 2/0.45 mm 6/0.45 mm 26.9 56.09 1/16" 4.5/0.225 mm 33.8 56.11 1/8" 9/0.45 mm 16.9 56.11 1/16" 3/16" 33.8 56.13 5/0.225 mm 17/32" 10.7 56.24 5/0.45 mm 17/32" 10.7 56.24 3/32" 7/0.45 mm 22.5 56.36 1/16" 5/0.45 mm 33.5 56.85 7/32" 19/32" 9.6 56.93 3.5/0.225 mm 10/0.45 mm 15.1 57.25 4/0.225 mm 7/16" 13.2 57.26 4/0.45 mm 7/16" 13.2 57.26 5/32" 7/16" 13.3 57.73 1/32" 3/0.45 mm 65.9 58.29 6/0.45 mm 21/32" 8.7 58.61 4.5/0.225 mm 1/2" 11.6 58.71 3/0.225 mm 11/32" 17.3 58.92 3/0.45 mm 11/32" 17.3 58.92 3/16" 17/32" 10.9 59.15 4.5/0.225 mm 13/0.45 mm 11.5 59.26 1.5/0.225 mm 4.5/0.225 mm 34.4 59.51 3/0.225 mm 9/0.45 mm 17.2 59.51 3/0.45 mm 9/0.45 mm 17.2 59.51 1.5/0.225 mm 3/16" 34.4 59.53 3/32" 9/32" 21.6 59.54 5/0.225 mm 9/16" 10.3 59.85 5/0.45 mm 9/16" 10.3 59.85 7/32" 5/8" 9.2 60.15 1.5/0.225 mm 5/0.45 mm 34.1 60.25 3.5/0.225 mm 13/32" 14.6 60.50 4/0.225 mm 12/0.45 mm 12.6 61.15 4/0.45 mm 12/0.45 mm 12.6 61.15 1/8" 3/8" 15.9 61.17 5/32" 12/0.45 mm 12.7 61.62 4/0.225 mm 15/32" 12.6 61.66 4/0.45 mm 15/32" 12.6 61.66 2/0.225 mm 1/4" 25.0 62.10 2/0.45 mm 1/4" 25.0 62.10 5/32" 15/32" 12.6 62.13 4.5/0.225 mm 17/32" 11.0 62.55 3/16" 9/16" 10.4 62.76 1/16" 5/0.225 mm 31.1 63.09 1/8" 10/0.45 mm 15.5 63.09 7/32" 21/32" 8.9 63.21 5/0.225 mm 19/32" 9.9 63.25 5/0.45 mm 19/32" 9.9 63.25 3.5/0.225 mm 11/0.45 mm 14.0 63.50 3/0.225 mm 3/8" 16.2 64.57 3/0.45 mm 3/8" 16.2 64.57 3.5/0.225 mm 7/16" 13.7 65.26 3/32" 8/0.45 mm 20.1 65.46 4/0.225 mm 1/2" 11.9 65.77 4/0.45 mm 1/2" 11.9 65.77 4.5/0.225 mm 9/16" 10.6 66.16 3/16" 19/32" 10.0 66.17 5/32" 1/2" 12.0 66.24 4/0.225 mm 13/0.45 mm 11.9 66.32 4/0.45 mm 13/0.45 mm 11.9 66.32 1/8" 13/32" 14.9 66.34 5/0.225 mm 5/8" 9.5 66.47 5/0.45 mm 5/8" 9.5 66.47 1.5/0.225 mm 5/0.225 mm 31.5 66.49 3/0.225 mm 10/0.45 mm 15.8 66.49 3/0.45 mm 10/0.45 mm 15.8 66.49 3/32" 5/16" 19.9 66.51 5/32" 13/0.45 mm 11.9 66.79 1/0.225 mm 3.5/0.225 mm 47.1 66.81 2/0.225 mm 7/0.45 mm 23.6 66.81 2/0.45 mm 7/0.45 mm 23.6 66.81 1/16" 7/32" 29.7 66.85 1/0.225 mm 4/0.45 mm 46.5 67.79 1/32" 1/8" 58.6 67.87 3.5/0.225 mm 12/0.45 mm 13.1 69.15 1/8" 11/0.45 mm 14.4 69.34 3/16" 5/8" 9.6 69.39 5/0.225 mm 21/32" 9.1 69.53 5/0.45 mm 21/32" 9.1 69.53 4.5/0.225 mm 19/32" 10.1 69.57 4/0.225 mm 17/32" 11.4 69.61 4/0.45 mm 17/32" 11.4 69.61 3.5/0.225 mm 15/32" 13.0 69.66 3/0.225 mm 13/32" 15.1 69.74 3/0.45 mm 13/32" 15.1 69.74 1/32" 3/0.225 mm 57.1 69.93 1/16" 6/0.45 mm 28.5 69.93 2/0.225 mm 9/32" 22.6 69.99 2/0.45 mm 9/32" 22.6 69.99 5/32" 17/32" 11.4 70.08 1.5/0.225 mm 7/32" 30.1 70.25 1/0.225 mm 5/32" 44.8 70.76 1/8" 7/16" 14.1 71.10 3/16" 21/32" 9.2 72.45 3/0.225 mm 11/0.45 mm 14.6 72.73 3/0.45 mm 11/0.45 mm 14.6 72.73 3/32" 11/32" 18.3 72.76 4.5/0.225 mm 5/8" 9.7 72.79 4/0.225 mm 9/16" 10.9 73.22 4/0.45 mm 9/16" 10.9 73.22 1.5/0.225 mm 6/0.45 mm 28.9 73.32 3/32" 9/0.45 mm 18.2 73.35 5/32" 9/16" 10.9 73.69 3.5/0.225 mm 1/2" 12.3 73.77 3.5/0.225 mm 13/0.45 mm 12.2 74.32 3/0.225 mm 7/16" 14.2 74.49 3/0.45 mm 7/16" 14.2 74.49 1/8" 12/0.45 mm 13.4 74.99 1/8" 15/32" 13.3 75.50 4.5/0.225 mm 21/32" 9.3 75.84 1/0.225 mm 4/0.225 mm 41.9 75.91 2/0.225 mm 8/0.45 mm 21.0 75.91 2/0.45 mm 8/0.45 mm 21.0 75.91 1/16" 1/4" 26.4 75.94 4/0.225 mm 19/32" 10.4 76.62 4/0.45 mm 19/32" 10.4 76.62 2/0.225 mm 5/16" 20.7 76.97 2/0.45 mm 5/16" 20.7 76.97 5/32" 19/32" 10.4 77.09 3.5/0.225 mm 17/32" 11.7 77.61 3/0.225 mm 12/0.45 mm 13.5 78.39 3/0.45 mm 12/0.45 mm 13.5 78.39 3/32" 3/8" 17.0 78.41 3/0.225 mm 15/32" 13.4 78.90 3/0.45 mm 15/32" 13.4 78.90 1.5/0.225 mm 1/4" 26.7 79.34 1/8" 1/2" 12.6 79.61 4/0.225 mm 5/8" 10.0 79.84 4/0.45 mm 5/8" 10.0 79.84 1/8" 13/0.45 mm 12.5 80.16 5/32" 5/8" 10.0 80.31 3/32" 10/0.45 mm 16.6 80.32 1/32" 3.5/0.225 mm 49.6 80.65 1/16" 7/0.45 mm 24.8 80.65 3.5/0.225 mm 9/16" 11.2 81.22 1/32" 4/0.45 mm 49.0 81.63 4/0.225 mm 21/32" 9.6 82.90 4/0.45 mm 21/32" 9.6 82.90 3/0.225 mm 1/2" 12.7 83.00 3/0.45 mm 1/2" 12.7 83.00 2/0.225 mm 11/32" 19.0 83.21 2/0.45 mm 11/32" 19.0 83.21 5/32" 21/32" 9.6 83.37 1/8" 17/32" 12.0 83.45 3/0.225 mm 13/0.45 mm 12.6 83.56 3/0.45 mm 13/0.45 mm 12.6 83.56 3/32" 13/32" 15.9 83.58 1/0.225 mm 4.5/0.225 mm 37.8 83.80 2/0.225 mm 9/0.45 mm 18.9 83.80 2/0.45 mm 9/0.45 mm 18.9 83.80 1/0.225 mm 3/16" 37.8 83.82 1/16" 9/32" 23.8 83.83 1.5/0.225 mm 7/0.45 mm 25.1 84.05 1/0.225 mm 5/0.45 mm 37.4 84.54 1/32" 5/32" 47.1 84.60 3.5/0.225 mm 19/32" 10.7 84.62 3/32" 11/0.45 mm 15.3 86.57 3/0.225 mm 17/32" 12.1 86.84 3/0.45 mm 17/32" 12.1 86.84 1/8" 9/16" 11.4 87.06 1.5/0.225 mm 9/32" 24.1 87.23 3.5/0.225 mm 5/8" 10.2 87.84 3/32" 7/16" 14.9 88.33 2/0.225 mm 3/8" 17.6 88.86 2/0.45 mm 3/8" 17.6 88.86 1/32" 4/0.225 mm 43.9 89.75 1/16" 8/0.45 mm 22.0 89.75 3/0.225 mm 9/16" 11.5 90.45 3/0.45 mm 9/16" 11.5 90.45 1/8" 19/32" 10.9 90.46 1/0.225 mm 5/0.225 mm 34.4 90.78 2/0.225 mm 10/0.45 mm 17.2 90.78 2/0.45 mm 10/0.45 mm 17.2 90.78 1/16" 5/16" 21.6 90.81 3.5/0.225 mm 21/32" 9.8 90.90 3/32" 12/0.45 mm 14.2 92.23 3/32" 15/32" 14.1 92.74 1.5/0.225 mm 8/0.45 mm 22.2 93.15 1/8" 5/8" 10.4 93.68 3/0.225 mm 19/32" 11.0 93.86 3/0.45 mm 19/32" 11.0 93.86 2/0.225 mm 13/32" 16.4 94.03 2/0.45 mm 13/32" 16.4 94.03 1.5/0.225 mm 5/16" 21.9 94.20 1/0.225 mm 7/32" 32.6 94.54 1/8" 21/32" 10.0 96.74 3/32" 1/2" 13.3 96.84 2/0.225 mm 11/0.45 mm 15.8 97.03 2/0.45 mm 11/0.45 mm 15.8 97.03 1/16" 11/32" 19.9 97.05 3/0.225 mm 5/8" 10.5 97.08 3/0.45 mm 5/8" 10.5 97.08 3/32" 13/0.45 mm 13.2 97.40 1/0.225 mm 6/0.45 mm 31.3 97.62 1/32" 4.5/0.225 mm 39.4 97.64 1/16" 9/0.45 mm 19.7 97.64 1/32" 3/16" 39.4 97.66 1/32" 5/0.45 mm 39.0 98.38 2/0.225 mm 7/16" 15.4 98.79 2/0.45 mm 7/16" 15.4 98.79 3/0.225 mm 21/32" 10.1 100.14 3/0.45 mm 21/32" 10.1 100.14 1.5/0.225 mm 11/32" 20.0 100.45 3/32" 17/32" 12.6 100.68 1.5/0.225 mm 9/0.45 mm 19.9 101.04 2/0.225 mm 12/0.45 mm 14.6 102.68 2/0.45 mm 12/0.45 mm 14.6 102.68 1/16" 3/8" 18.3 102.70 2/0.225 mm 15/32" 14.5 103.19 2/0.45 mm 15/32" 14.5 103.19 1/0.225 mm 1/4" 28.7 103.63 3/32" 9/16" 12.0 104.29 1/32" 5/0.225 mm 35.7 104.62 1/16" 10/0.45 mm 17.9 104.62 1.5/0.225 mm 3/8" 18.5 106.10 2/0.225 mm 1/2" 13.6 107.30 2/0.45 mm 1/2" 13.6 107.30 3/32" 19/32" 11.4 107.70 2/0.225 mm 13/0.45 mm 13.5 107.85 2/0.45 mm 13/0.45 mm 13.5 107.85 1/16" 13/32" 17.0 107.87 1.5/0.225 mm 10/0.45 mm 18.0 108.02 1/0.225 mm 7/0.45 mm 26.9 108.34 1/32" 7/32" 33.8 108.38 1/16" 11/0.45 mm 16.3 110.87 3/32" 5/8" 10.9 110.92 2/0.225 mm 17/32" 12.9 111.14 2/0.45 mm 17/32" 12.9 111.14 1.5/0.225 mm 13/32" 17.2 111.27 1/32" 6/0.45 mm 32.4 111.46 1/0.225 mm 9/32" 25.7 111.52 1/16" 7/16" 15.9 112.63 3/32" 21/32" 10.4 113.98 1.5/0.225 mm 11/0.45 mm 16.4 114.26 2/0.225 mm 9/16" 12.2 114.75 2/0.45 mm 9/16" 12.2 114.75 1.5/0.225 mm 7/16" 16.0 116.02 1/16" 12/0.45 mm 15.0 116.52 1/16" 15/32" 14.9 117.03 1/0.225 mm 8/0.45 mm 23.6 117.44 1/32" 1/4" 29.7 117.47 2/0.225 mm 19/32" 11.7 118.15 2/0.45 mm 19/32" 11.7 118.15 1/0.225 mm 5/16" 23.2 118.50 1.5/0.225 mm 12/0.45 mm 15.1 119.92 1.5/0.225 mm 15/32" 15.0 120.43 1/16" 1/2" 14.1 121.14 2/0.225 mm 5/8" 11.1 121.37 2/0.45 mm 5/8" 11.1 121.37 1/16" 13/0.45 mm 13.9 121.69 1/32" 7/0.45 mm 27.7 122.18 2/0.225 mm 21/32" 10.6 124.43 2/0.45 mm 21/32" 10.6 124.43 1.5/0.225 mm 1/2" 14.1 124.53 1/0.225 mm 11/32" 21.2 124.74 1/16" 17/32" 13.3 124.98 1.5/0.225 mm 13/0.45 mm 14.0 125.09 1/0.225 mm 9/0.45 mm 21.0 125.33 1/32" 9/32" 26.4 125.36 1.5/0.225 mm 17/32" 13.4 128.37 1/16" 9/16" 12.6 128.59 1/0.225 mm 3/8" 19.4 130.39 1/32" 8/0.45 mm 24.2 131.28 1.5/0.225 mm 9/16" 12.7 131.98 1/16" 19/32" 12.0 131.99 1/0.225 mm 10/0.45 mm 18.9 132.31 1/32" 5/16" 23.8 132.34 1/16" 5/8" 11.4 135.21 1.5/0.225 mm 19/32" 12.0 135.39 1/0.225 mm 13/32" 18.0 135.56 1/16" 21/32" 10.9 138.27 1/0.225 mm 11/0.45 mm 17.2 138.56 1/32" 11/32" 21.6 138.58 1.5/0.225 mm 5/8" 11.4 138.61 1/32" 9/0.45 mm 21.5 139.17 1/0.225 mm 7/16" 16.7 140.32 1.5/0.225 mm 21/32" 10.9 141.67 1/0.225 mm 12/0.45 mm 15.8 144.21 1/32" 3/8" 19.9 144.23 1/0.225 mm 15/32" 15.6 144.72 1/32" 10/0.45 mm 19.3 146.15 1/0.225 mm 1/2" 14.7 148.83 1/0.225 mm 13/0.45 mm 14.6 149.38 1/32" 13/32" 18.3 149.40 1/32" 11/0.45 mm 17.5 152.40 1/0.225 mm 17/32" 13.8 152.67 1/32" 7/16" 17.0 154.16 1/0.225 mm 9/16" 13.1 156.28 1/32" 12/0.45 mm 16.0 158.05 1/32" 15/32" 15.9 158.56 1/0.225 mm 19/32" 12.4 159.68 1/32" 1/2" 14.9 162.67 1/0.225 mm 5/8" 11.8 162.90 1/32" 13/0.45 mm 14.8 163.22 1/0.225 mm 21/32" 11.3 165.96 1/32" 17/32" 14.1 166.51 1/32" 9/16" 13.3 170.12 1/32" 19/32" 12.6 173.52 1/32" 5/8" 12.0 176.74 1/32" 21/32" 11.4 179.80
