Lor's Electronic Heart
The symbol of love ❤️
Public Chat
I made this project several times to give to my loved ones to show how much i love them, although they never asked me to i just did. All the major components used in the project i salvaged from scrap even the capacitors are from old electronics. Heart of my Heart project is my favorite Ne555 chip.
In this video i have shown every thing to make a Lor's Electronic Heart.
the heart is equiped with a nokia bl-5c with a small round pin female port for nokia charger
This one uses same battery i.e. nokai bl-5c but with tp4056 module :)
This one is running from Arduino Generated pulse
  • 1 × NE555 Used to build an Astable multivibrator
  • 1 × 1uf Electrolytic Capacitor
  • 1 × Thread spool for wrapping the li-ion cell
  • 1 × Glittered foam sheet to cut out a heart from.
  • 2 × .1uf ceramic Capacitor (104)
View all 12 components
  • 1
    Collect all the components needed for this project
    hardest and the easiest component to find depending upon where you live is the CD-Player lens which is literally the heart of this project. you can easily find one from your local scrap store (if you have one near you)  because due to ever increasing e-waste around the world this type of components are very easy to find. other than that  everything can be found very easily like the Li-ion cell, TP4056 module, perf board, Capacitors, Resistors, super glue and other parts.
  • 2
    build the circuit
    the circuit for this project is very easy to build i am providing you with the circuit below if find any difficulties making the circuit to work  let me know.
  • 3
    Assemble everything
    1. Cover the cell with Thread to make it bit not ugly.
    2. Place all the components on perf board before soldering to make sure everything fits under the board size.
    3. Solder NE555 ic with other passive components including the tactile switch, then solder TP4056 module and then the lens itself.
    4. cut out a heart from glitter covered foam sheet (or just buy already cut heart) and attach it to the lens using very little amount of super glue (make sure not to jam the lens).
    5. use two compound adhesive or super glue for attaching the pcb to cell.
View all 3 instructions
[deleted]
Deepak Khatri wrote 07/27/2019 at 19:02 point
yeah, you are right. i'll update it soon!
Jeffrey Jacques wrote 01/05/2019 at 09:04 point
Got a parts list or schematic?
Deepak Khatri wrote 02/06/2019 at 15:36 point
I am working on detailed explanation of this project wait for it ;)
Dan Maloney wrote 01/04/2019 at 16:10 point
So what's making the heart move?
Solenoid?
Deepak Khatri wrote 02/06/2019 at 15:39 point
i used an old CD player lens for that in which we have coils for horizontal and vertical motion of lens, i used the vertical coil for this (polarity matters i used the vertical coil  for upward motion reverse will make it go down)
