More photos
01/08/2019 at 21:22 • 0 commentsHey folks, here are a couple more pics.
For the one of the back plate, this is 1/8 steel scrap that I had. I like the patina.
From left to right you have- USB for MIDI / power supply
- 1/4 MONO line-level audio out
- Octave down
- Octave up
- Joystick. vertical axis makes the controller louder / softer. Horizontal controller bends pitches
- Four Red control buttons. (well 3 because the bottom one already broke. No more cheap switches for me!) They are:
- cheap-ass broken button
- unassigned
- Change pitch bend between entire instrument mode or last note played mode
- change wave form
- Two LEDs that initially showed which of the 5 octaves was selected, from one (bottom blinks twice) , 2 (bottom blinks once), 3 (no lights), 4 (top blinks once) and 5 (top blinks twice). I disconnected them because the blinking was distracting.
There is also a close up of the keys, where you can see the round Cherry MX key caps I am using for the buttons. There is not really a pattern to what letters go to what switches other then the C-G in the middle. The black keys are just white keys with sharpie.
You can see how tight I am for space on the back. Im leaning towards making this model MIDI only and building a second prototype with a little more room.
Initial upload
01/07/2019 at 06:51 • 0 commentsInitial upload and prototype. Features include
- Midi over USB out (note on and note off)
- 3 octave keyboard. up to 5 selective octave ranges
Audio Synthesis features
- Multiple wave forms, including
- Sine
- Sawtooth
- Reverse Sawtooth
- Pulse
- Square
- Frequency range of to 81.8 to 12543.85 hz
- polyphonic up to 4 notes. Additional notes cause earliest note to drop out
- analog joystick. One axis is overall volume the other is pitch bend.
- Pitch bend can be switched between the entire interface or just the last note played
- Pitch bend moves 1/2 step either direction
still to do:
- add the audio shield for better sound quality
- add more interesting sounds with different sorts of sound synthesis (looking at FM modulation)
jonHickam
