Electronic Ghost
This spooky electronic ghost is a 555 LED flasher circuit encapsulated in silicone rubber.
Public Chat
How do electronic ghosts think?
In BOOlean logic.
Ghost Cutter.stl
stl-binary - 108.09 kB - 01/06/2019 at 12:52
Download
  • 2 × Blue LED
  • 1 × 555 Prototyping Products / PCB Chemicals
  • 3 × 1 kOhm resistor
  • 1 × 10 kOhm resistor
  • 1 × 0.01 uF ceramic capacitor
View all 8 components
  • 1
    Making the ghost shape
    Before soldering the circuit, I 3D printed the shape of the ghost. You can download the stl file from here.
  • 2
    Soldering the circuit
    The schematic is a very simple one which you can find here.
    I cut two holes in the lower part of the ghost shape, in order to solder the battery holder on the outside. This way the silicone didn't get stuck in the battery holder.
  • 3
    Potting
    Adding the silicone was a bit tricky, because of the air bubbles. I tried heating the ghost hoping the bubbles would rise to the surface, but it didn't work as expected.
View all 4 instructions
Elliot Williams wrote 01/12/2019 at 21:24 point
Tidy project. Horrible pun.
Mike Szczys wrote 01/08/2019 at 15:16 point
3D printed mold is a really nice touch. Well done!
Zalmotek wrote 01/09/2019 at 07:42 point
Thank you!
Lee Wilkins wrote 01/07/2019 at 18:44 point
This looks really cool. Do you have any more info on the silicon process?
Zalmotek wrote 01/07/2019 at 19:13 point
Thanks! This was my first attempt at using it. This is the silicone I've used: https://www.tme.eu/en/details/e43-90ml/encapsulating-materials/wacker/. Not the best choice, but I couldn't find an epoxy one. The one I've used remains elastic after drying and so far it didn't seem to affect the circuit.
Dan Maloney wrote 01/07/2019 at 16:11 point
BOOlean, lol...
So that silicone you used - I suppose it's not the kind that reeks of acetic acid, right? I've been looking for potting silicone.
Zalmotek wrote 01/07/2019 at 19:00 point
It is actually, I've read it's not exactly suitable for electronics but it's the only type I could find. This is the one I've used: https://www.tme.eu/en/details/e43-90ml/encapsulating-materials/wacker/
Amos wrote 01/06/2019 at 13:49 point
Cute idea! 8^)
Zalmotek wrote 01/06/2019 at 16:00 point
Thanks! :D
