Zeit für Ellerton / Time for Ellerton
Attiny45 controlled Solarmotors turn small muffin paper cups. The circuit is mounted directly on the wall, with Aluminium and copper tape.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This installation was a side specific art work in an exhibition-room in Cologne, 2017.
The circuit is sticked directly on the wall with thin copper and aluminium tape. I used Attiny45 to control the motors and LEDs and also some transistors and resistors, everything soldered on that tape. I am interested in the contrast between the straight and linear circuit aesthetics and the organic lightness of the muffin cups.
Even if it took me lots of hours to realize it, it was only a temporary intervention and I had to remove everything when the exhibition was over. But I go on with that concept in other exhibitions :)
