The clock is simple. Arduino reads the time from RTC module and displays the digits on a single 4 digit matrix display. A start up message can also be displayed.
The HDSP-2000 series matrix displays come in red, yellow, green & various different sizes; they are often used in aircraft display panels. The MSD2313 is an analog of the HDSP 2000 manufactured by Siemens. The display is a beautiful example of engineering featuring ceramic, glass and gold, containing 2 shift registers / driver ICs and 140 individual LED die which make up the 4 character 5x7 bit mapped digits.
The Arduino sends serial data (28bits) to the input of the display chip (more than 1 can be linked in series). The 5 columns are driven one at a time, using a UDN2981 source driver (opposite equivalent to ULN2803 Darlington array) which can source up to 500mA per output pin.
Patrick Hickey
Jeff Wahaus
brett.oliver
Se puede utilizar en su defecto el display hcms 2003?
