A Telescoping Yagi Antenna with telescoping boom and telescoping antenna elements for mechanical tunability. The antenna elements also fold back for more compact portability.
01/17/2021 Update: Added new vers2 design files that fit SCH.40 1/2" PVC-1 D-2466 Tees. Also, no hole drilling required.
Details
Files
Yagi_Telescoping_Mount_v2_halfsz.gcode
gcode of the @ 0.1 vertical height (res), 30% honeycomb infill and 5 layers rectilinear perimeters for the MPSM V2
Just noticed I didn't reference using the Tecsun AN-07 Telescopic Antenna Extender on the reflecting elements. Figured I'd note as an easy packable way to further mechanically tune the antenna a little lower down.
