Yagi_Telescoping_Mount_v2_halfsz.gcode
gcode of the @ 0.1 vertical height (res), 30% honeycomb infill and 5 layers rectilinear perimeters for the MPSM V2
gcode - 6.82 MB - 01/18/2021 at 06:33
Download
Yagi_Telescoping_Mount_v2_halfsz.stl
Version 2.1 half length, 42mm design .stl
Standard Tesselated Geometry - 261.12 kB - 01/18/2021 at 06:32
Download
Yagi_Telescoping_Mount_v2.gcode
gcode of the @ 0.1 vertical height (res), 25% honeycomb infill and 5 layers rectilinear perimeters for the MPSM V2
gcode - 15.28 MB - 01/18/2021 at 04:43
Download
Yagi_Telescoping_Mount_v2.stl
Version 2 .stl
Standard Tesselated Geometry - 161.51 kB - 01/18/2021 at 04:39
Download
Yagi_Telescoping_Mount_v2.rsdoc
Version 2 in the DesignSpark Mechnical file format.
rsdoc - 144.38 kB - 01/18/2021 at 04:39
Download
Telescoping_Yagi_ToDoList.docx
To Do List of next tasks I need to complete. Scribing antenna and associated boom length resonant frequencies and color coding those location can be added to the list. Needs to be updated.
document - 6.55 kB - 01/08/2019 at 22:42
Download
RDF_Telescopic_Yagi_Antenna_Calculator.ods
Not the prettiest spreadsheet... though aids in theoretical calculations. Needs to be updated.
spreadsheet - 18.89 kB - 01/08/2019 at 22:42
Download
Yagi_Telescopic_Element_Mount2.STL
STL file for the raw Antenna Element Mount
Standard Tesselated Geometry - 26.55 kB - 01/08/2019 at 22:34
Download
Yagi_Telescopic_Element_Mount2.SLDPRT
SolidWorks file for the raw Antenna Element Mount
sldprt - 122.25 kB - 01/08/2019 at 22:34
Download
