This hardware contains 15 pcs of BPW21R PIN
diode sensor. PIN diode sensors are used for
detecting visible luminance and using of this
PIN diodes for detecting invisible Rays like X
Ray is uncommon and there are expensive
sensors for this application.
I designed a Hardware for detecting High power
invisible Radiations by this ultra-cheap sensor
type.
It is so fast and Extremely accurate in X Ray
detection.
oh, I assumed it was abandoned because only the general idea was shared and nothing more. if possible, can you please share with me the hardware used and how you did accomplish sensing x-ray using this type of sensor.
great for you, now... what happened to this project, abandoned ?
